Ajuda 6L 130 ja pega mas sem quadrante ( Já Anda)
VCDS Version: Beta 11.8.0
Data version: 20110831
Sunday,13,November,2011,15:23:02:10074
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 LA
Component: 1,9l R4 EDC 0410SG 5405
Coding: 00102
Shop #: WSC 12345
VCID: 61CDA1B7C650
VSSZZZ6LZ4R073595 SEZ7Z0C2186057
2 Faults Found
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 6Q0-907-37x-ESP.lbl
Part No: 6Q0 907 379 Q
Component: ESP 5.7 front H03 0000
Coding: 0003353
Shop #: WSC 06403 000 00000
VCID: 4B91631F54DC
1 Fault Found
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 00396
Shop #: WSC 06402
VCID: 3B7133DF047C
6 Faults Found
49-00 - No Communications
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
00969 - Fuse for Heated Rear Window (S41)
37-00 - Faulty
00511 - Selector Lever (E313)
01324 - Control Module for All Wheel Drive (J492)
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 AE
Component: 0E AIRBAG VW5 07 0008
Coding: 12357
Shop #: WSC 06441
VCID: 7AFFF6DB4BC6
2 Faults Found
00532 - Supply Voltage B+
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 60 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06402
VCID: F0EB54F39DBA
4 Faults Found
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 S
Component: LenkhilfeTRW V260
Coding: 10161
Shop #: WSC 06402
VCID: 3F8947CF1064
2 Faults Found
01317 - Unlicensed Version. Not all DTCs
49-00 - will be decoded.
pronto a situação é esta.
eu ia a andar bem com ele ontem a noite, e derrepente o quadrante desliga, mas o carro a puchar na boa e tudo ok, estacionei desliguei e voltei a ligar e nunca mais pegou...
o quadrante nao dá luzes nehumas .. enfim .. acho que o vou enfardar..
Assim por alto parece-me problemas no quadrante imobilizador ou centralina.
Vi ao site wiki ross tech e pesquisa os fault codes, pode ser se consigas saber o que é.
Penso que sera imobilizador.
EU no teu caso desligava a bateria, desmontava o quadrante desligava fichas e ligava/montava novamente, ligava a bateria (20 minutos de trabalho).
Nao custa nada tentar porque é algo que podes ser tu a fazer.
tenho o carro todo desmontado, ja vi fusiveis já vi tudo , ja desliguei tambem a bateria, OMG so me faltava + esta..
oico o carro a puchar o gasoleo pega e depois vai abaixo . (imobilizador)
Pronto ja podias ter dado essa informacao.
O carro pega, 2/3 segundos depois vai abaixo. ok 100% certeza imobilizador.
O teu xipador que te programe isso ou entao seat, nao ha mais nada a fazer.
yap , ja falei com ele, ja tirei a centralina / quadrante, vamos analisar a situação. abraço vamos ver se pega :d
Bem pah, andas com azar :roll:
Não sou grande expert no assunto, mas isso parece-me imobilizador.
Pq tenho o mesmo problema com um chave que me falta "casar". O carro pega, mas vai abaixo :roll:
vou re-soldar o quadrante e vou testar. (já que tenho maquina) ;-)
ele ia tão bem a 160km a subir e no meio tem uma mini lomba.. foi ai que ele desligou o vermelho (luzes) e os ponteiros cairam, mas continuando a puchar na mesma e a andar cheguei ao destino bem, desliguei-o pronto nunca mais pegou, + uma volta de reboque ...
Pois, tudo faz apontar para o quadrante. O estranho mesmo é já estar montado aí um quadrante de 4 manómetros que supostamente é bem mais viável do que o de 6 manómetros e mesmo assim estar a dar complicações...
Ja me aconteceu amigo, mas foi um dia que ia pa ligar o carro e ele me fez isso, mas eu tenho luzes, so ficou lixado so mesmo o imobilizador, abraço, espero que tudo se resolva :)
