[Vag-com] Alguns Erros encontrados.
Boas ppl, esta tarde eu e o k2o3 tivemos a fazer um scan ao carro dele e encontramos alguns erros, opinem acerca dos mesmos pois andamos á nora. ja apagámos, mas eles na nova busca estao lá na mesma...
como ek se apagam definitivamente???
agradeço::.
cumps::.
-------------------------ERROS ENCONTRADOS---------------------------
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Controller: 038 906 019 LA
Component: 1,9l R4 EDC 0000SG 5405
Coding: 00102
Shop #: WSC 06402
VSSZZZ6LZ4R214574 SEZ7Z0D2482635
1 Fault Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V40
Coding: 00188
Shop #: WSC 06403
1 Fault Found:
65535 - Internal Control Module Memory Error
35-00 - -
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00140
Shop #: WSC 06402
1 Fault Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 820 K
Component: KOMBI+WEGFAHRSP VDO V12
Coding: 00145
Shop #: WSC 00000
1 Fault Found:
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 0060 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
1 Fault Found:
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 01 Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
1 Fault Found:
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
End -------------------------------------------------------
spool disse:
P1649 - 35-00 - -
35-00 - -
1ª Falha - Falha de comunicação com o modulo... possivel curto circuito , ou falha do sensor de ABS!
2ª Falha - Curto circuito com a centralina durante o arranke do motor!
Pode aontecer quando por exemplo tentas ligar o carro com ele engatado!
Ou o desligar da bateria durante mais de 20 min.
Caso extremo pode ser a centralina a dar o berro...mas se nao tivestes prob com o carro em termos ele se engasgar por exe em Auto-estrada! .. em principio foi so um curto circuito, que pode nao mais acontecer!
3ª,4ª e 5ª Falhas - Neste caso é mesmo falha de comunicação com o modulo de ABS.
6ª Falha - Falha da pistola de disparo do fecho do lado direito ..se vês que ele mesmo assim fecha bem... pode ser má comunicação com o sensor (prob electricos).
PS: Não tiveste nenhuma fuga de oleo durante algum tempo dentro do compartimento do motor?!?!
O oleo danifica cabos borrachas ..diminuindo a continuidade electrica e podendo queimar alguns sensores!
gafrancisco disse:
gafrancisco o carro nunk se engasgou, nem em AE nem ao ligar o carro pelo menos eu nunk notei nada :? , em termos de ABS sempre funciono bem... Fugas d oleo no motor k sejam visiveis tb n tem nada pk kd o comprei lavei o motor e ele ainda continua limpo :? ... Axas k dá para resolver esses erros???
opá limpa os erros e depois ve se aparecem de novo!
se aparecerem logo de seguida tens de ver os sensores
se aparecerem tipo 3 ou 4 dias depois ..pode ser cabelagens!
Boas, agente limpa os erros, desliga o vag-com e volta a ligar e já lá estao os erros de novo...:mad:
como ek se vÊ os sensores?
oficina???
abraços:..
Spool,atenção que para limpar os erros não é no manu de testes... tens k entrar mesmo no menu de cada componente e ai fazer a limpeza.
Alguma coisa, apita
Boas noosphere, ta td?
epah so agora ek vi o post...
Sim, nos vamos a cada grupo e apagamos..
voltamos a fazer o scan, e os erros ja n aparecem, mas ao ligar o carro novamente, os erros estao la de novo...
Penso de a avaria ser mesmo mecanica...
cumps:...
Ah, pois... assim sendo deve haver ai algum problema :(
Talvez seja melhor irem com ele á "garantia" ... Eu tb tenho aki uns problems nos flaps da sofagem e até tenho medo de o meter a arranjar :mad:
