MiguelTavares
S.T.A.F.F.
Seat Ibiza 6L 1.4TDI Ecomotive - DPF (out)
Alguém me ajuda nestes erros?
Code:
012296 - Camshaft Position Sensor (G40): Signal Out of Range
P3008 - 000 - - - Intermittent
Freeze Frame
Fault Status: 00110000
Fault Priority: 3
Fault Frequency: 1
Mileage: 33400 km
Time Indication: 0
Freeze Frame
RPM: 4641 /min
(no units): 3.0
Load: 100.0 %
Voltage: 14.06 V
Temperature: 66.6°C
Idle Stabilization: 57.1°KW
000833 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 000 - - - Intermittent
Freeze Frame
Fault Priority: 3
Fault Frequency: 1
Mileage: 33400 km
Time Indication: 0
Freeze Frame
RPM: 4788 /min
(no units): 3.0
Load: 100.0 %
Voltage: 14.14 V
Temperature: 66.6°C
008597 - Oxygen (Lambda) Sensor B1 S1: Signal too Low (Lean)
P2195 - 000 - - - Intermittent
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Mileage: 34053 km
Time Indication: 0
Freeze Frame
RPM: 1596 /min
Speed: 39.0 km/h
(no units): 38.0
Temperature: 27.9°C
Absolute Pres.: 346.8 mbar
Voltage: 1.168 V
(no units): 0.03
