Ajuda erros Vag-com
Boa tarde pessoal
o meu carro acendeu a luz do catalisador segundo o manual e liguei o vag-com e os erros sao os seguintes:
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: Malfunction 0010
Address 4B: Multifunc. Module Labels: None
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: F0EB54F39A33
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
004 - No Signal/Communication - Intermittent
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 HW: 6R0 937 087
Component: PQ25 BCM H07 0012
Revision: BF007001 Serial number: 9425B298082469
Coding: 3D8829FF88610100082006007FEB1CC80080420F608C00002000
Shop #: WSC 00570 223 84847
VCID: FAFF76DBCC4F
Part No SW: 6R0 959 801 A HW: 6R0 959 801 A
Component: J386__TSG_FT 001 0238
Coding: 020000
Part No SW: 6R0 959 802 B HW: 6R0 959 802 B
Component: J387__TSG_BT 001 0233
Coding: 020000
Part No SW: 6R0 959 591 HW: 6R0 959 591
Component: J245/J878 H04 0054
Coding: 000003
2 Faults Found:
00063 - Back-Up Light Switch (F4)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 237
Mileage: 96385 km
Time Indication: 0
Date: 2110.14.27
Time: 00:20:19
00975 - Heated Rear Window (Z1)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 223
Mileage: 94685 km
Time Indication: 0
Date: 2110.14.04
Time: 00:00:01
Address 01: Engine Labels: None
Part No SW: 03G 906 013 K HW: 03G 906 013 K
Component: R4 1,9L EDC G000SG 2940
Revision: --H04--- Serial number:
Coding: 0053071
Shop #: WSC 00191 264 15243
VCID: 285BFC93E263
3 Faults Found:
001384 - Cruise Control Switch (E45): Implausible Signal
P0568 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 15
Mileage: 96926 km
Time Indication: 0
Freeze Frame:
RPM: 1344 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.94 V
Bin. Bits: 11101100
Bin. Bits: 11000000
(no units): 255.0
049508 - No Communications with HVAC Control Module (J301)
U0164 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 96705 km
Time Indication: 0
Freeze Frame:
RPM: 861 /min
Speed: 0.0 km/h
Load: 0.5 %
Voltage: 13.22 V
Bin. Bits: 00001100
Bin. Bits: 10000000
(no units): 1.0
001668 - Glow Plug Control Module (J179): Implausible Signal
P0684 - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 2
Mileage: 97073 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00101100
Temperature: 2.7°C
Bin. Bits: 00110000
Readiness: 1 1 0 0 1
Sera que alguem me pode ajudar a decifrar os erros para perceber o que tenho que fazer...
desde ja o meu muito obrigado
