VCDS - Ajuda - ERROS
Bom dia ,
preciso de ajuda para identificar os seguintes erros.
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 25.3.0 Data version: 20250301 DS365.0
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Wednesday,15,October,2025,21:29:30:00009
VIN: VSSZZZ6JZ9R115299 License Plate:
Mileage: 253500km-157517mi Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZ9R115299 Mileage: 253500km-157517miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: Malfunction 0010
56-Radio -- Status: Sporadic communication error 1000
VCDS
Self-Diagnosis Log
Page 2
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 013 K HW: 03G 906 013 K
Component: R4 1,9L EDC 0000SG 2940
Revision: --H04--- Serial number:
Coding: 0053071
Shop #: WSC 00001 001 00001
VCID: 285F4DA79BF312DBA8-807C
VINID: 9A38EAAAA19AA89881045089248AF4C316
3 Faults Found:
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 254
Reset counter: 255
Mileage: 245526 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 100.3 %
Bin. Bits: 00000100
Mass Air / Rev.: 610.0 mg/str
Mass Air / Rev.: 0.0 mg/str
001027 - EGR Valve (N18)
P0403 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 252387 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 4.0 km/h
Duty Cycle: 0.0 %
Voltage: 12.69 V
Duty Cycle: 17.0 %
Bin. Bits: 00110000
008825 - Leak in Air Intake System
P2279 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00110000
VCDS
Self-Diagnosis Log
Page 3
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 253336 km
Time Indication: 0
Freeze Frame:
RPM: 1575 /min
Speed: 42.0 km/h
Temperature: 35.1°C
Absolute Pres.: 1377.0 mbar
Absolute Pres.: 1366.8 mbar
(no units): 0.00
Inj. Quantity: 23.1 mg/str
Readiness: 0 1 0 0 0
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 H HW: 6R0 907 379 H
Component: ESP8.2i front H04 0005
Revision: --------
Coding: 110248DB016E00B7882712EB80DA00421200
Shop #: WSC 15641 784 75091
VCID: 4385FA0BC695D1839D-8016
No fault code found.
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 HW: 6J0 820 045
Component: J301 Klimaanlage 0280
Revision: 00 23 08 Serial number: 0000000094730-
Shop #: WSC 00000 000 00000
VCID: 63C51A8BA255B183BD-8036
VCDS
Self-Diagnosis Log
Wednesday,15,October,2025,21:29:31:00009
Page 4
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 HW: 6R0 937 087
Component: PQ25 BCM H07 0012
Revision: BF007001 Serial number: 9425B023090707
Coding: 3C8829A88861250092200000760B1CC80080400F608C00002000
Shop #: WSC 80093 222 69422
VCID: 7AFB47EFF5DF504B8E-802E
Subsystem 1 - Part No SW: 6R0 959 801 DT HW: 6R0 959 801 DT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 004 0630
Serial number: KU0KU026071882070987
Coding: 1000A5
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 001 0103
Coding: 000000
Subsystem 5 - Part No: 1K8 951 171 A
Coding: 000000
5 Faults Found:
03301 - Response Closing Status of Drivers Door
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 13
Reset counter: 152
Time Indication: 0
03302 - Response Closing Status of Passenger's Door
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 132
Mileage: 245526 km
Time Indication: 0
Date: 2020.03.07.
Time: 20:01:53
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
Time Indication: 0
VCDS
Self-Diagnosis Log
Page 5
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 242887 km
Time Indication: 0
Date: 2020.03.07.
Time: 00:00:04
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 28
Reset counter: 114
Mileage: 241525 km
Time Indication: 0
Date: 2020.03.07.
Time: 08:14:35
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10AirbagA02 H08 0018
Revision: -------- Serial number: 003000000000 Dataset Number: s00301926J0 0009
Coding: 003032
Shop #: WSC 06401 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 428BFF0FD58FD88B96-8016
Crash sensor for side airbag: driver side:
Serial number: 3492ERB401L8CLJATRRY
Crash sensor for side airbag: passenger side:
Serial number: 3502ERB403585LSITB4Q
VCDS
Self-Diagnosis Log
Page 6
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 6J0 920 800 L HW: 6J0 920 800 L
Component: KOMBI 017 0018
Serial number: 00000000000000
Coding: 110A00
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2F6DA6BB761D45E369-807A
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0012
Coding: 422000
VCID: 70EF65C7A3A31A1B30-8024
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Reset counter: 155
Time Indication: 0
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO 017 0018
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCDS
Self-Diagnosis Log
Page 7
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10111
Shop #: WSC 06402
VCID: 6DD17CB32091F7F31B-8038
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 70EF65C763A31A1B30-8024
2 Faults Found:
00470 - Company Comfort Databus in Single Wire
012 - Electrical Fault in Circuit - Intermittent
011 - Open Circuit - Intermittent
Address 56: Radio Labels: None
VCID: 55A13453BC015F33C3-FFFE
End-------------------------(Elapsed Time: 04:00)--------------------------
------------------------------11 Faults Found------------------------------
