deixo aqui o log para ver se me ajudam, 105hp com pó para uns 145cv, o turbo tem uma pequena passagem mas nada de morrer e estou com um safe
Mileage: 256340km/159282miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LK HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9249
Revision: --H07--- Serial number: SEZ7Z0G3818783
Coding: 0050071
Shop #: WSC 06325 000 00000
VCID: 73E539471240F3802D9
1 Fault Found:
000564 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition)
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 3
Mileage: 256341 km
Time Indication: 0
Date: 2000.00.00
Time: 16:26:48
Freeze Frame:
RPM: 3864 /min
Speed: 136.0 km/h
Load: 100.0 %
Voltage: 14.36 V
Bin. Bits: 00001000
Absolute Pres.: 2121.6 mbar
Absolute Pres.: 2560.2 mbar
Readiness: 1 1 0 0 0
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1129
Revision: 31008001 Serial number: 00000533278424
Coding: 0000176
Shop #: WSC 04941 785 00200
VCID: 3B75D1677A907BC0359
2 Faults Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 42
Reset counter: 180
Mileage: 256290 km
Time Indication: 0
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 14
Reset counter: 180
Mileage: 256290 km
Time Indication: 0
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 988000005283CC7F0006850560084F86307C80
VCID: 8305E987C2E04300BD9
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 04941
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 179
Time Indication: 0
isto foi a puxar a 4ª, vai as 4 rpm com 2.5 boost, é isso??? depois entra em safe e os valores baixam
,119.94,1701,1173.0,1336.2,58.0,,,,,,,,,,
,120.11,1701,1173.0,1305.6,60.0,,,,,,,,,,
,120.28,1701,1173.0,1275.0,61.9,,,,,,,,,,
,120.47,1701,1173.0,1244.4,63.9,,,,,,,,,,
,120.64,1701,1173.0,1213.8,65.5,,,,,,,,,,
,120.81,1701,1173.0,1193.4,66.7,,,,,,,,,,
,121.00,1701,1173.0,1173.0,68.3,,,,,,,,,,
,121.17,1680,1173.0,1162.8,69.4,,,,,,,,,,
,121.34,1680,1162.8,1142.4,69.4,,,,,,,,,,
,121.53,1680,1162.8,1132.2,70.6,,,,,,,,,,
,121.70,1659,1162.8,1122.0,71.4,,,,,,,,,,
,121.87,1659,1162.8,1122.0,71.8,,,,,,,,,,
,122.06,1659,1162.8,1111.8,73.0,,,,,,,,,,
,122.23,1659,1162.8,1101.6,73.8,,,,,,,,,,
,122.40,1638,1162.8,1101.6,73.8,,,,,,,,,,
,122.58,1638,1173.0,1091.4,75.0,,,,,,,,,,
,122.75,1638,1173.0,1091.4,75.4,,,,,,,,,,
,122.92,1638,1203.6,1091.4,78.1,,,,,,,,,,
,123.11,1638,1244.4,1081.2,80.9,,,,,,,,,,
,123.28,1617,1285.2,1081.2,82.9,,,,,,,,,,
,123.45,1638,1387.2,1101.6,90.3,,,,,,,,,,
,123.64,1638,1540.2,1142.4,90.3,,,,,,,,,,
,123.81,1638,1621.8,1183.2,90.3,,,,,,,,,,
,123.98,1638,1754.4,1224.0,90.3,,,,,,,,,,
,124.17,1659,1897.2,1264.8,90.3,,,,,,,,,,
,124.34,1659,1958.4,1295.4,87.6,,,,,,,,,,
,124.51,1680,1968.6,1377.0,82.1,,,,,,,,,,
,124.70,1680,1978.8,1479.0,79.7,,,,,,,,,,
,124.86,1701,1989.0,1560.6,80.5,,,,,,,,,,
,125.04,1722,1999.2,1642.2,78.1,,,,,,,,,,
,125.23,1743,2009.4,1713.6,76.5,,,,,,,,,,
,125.39,1764,2029.8,1774.8,73.0,,,,,,,,,,
,125.56,1785,2040.0,1836.0,66.7,,,,,,,,,,
,125.75,1827,2060.4,1907.4,63.1,,,,,,,,,,
,125.92,1869,2091.0,1968.6,60.4,,,,,,,,,,
,126.10,1890,2101.2,2050.2,54.8,,,,,,,,,,
,126.28,1932,2121.6,2121.6,52.5,,,,,,,,,,
,126.45,1974,2131.8,2193.0,49.7,,,,,,,,,,
,126.62,2016,2152.2,2244.0,46.9,,,,,,,,,,
,126.81,2058,2162.4,2325.6,41.0,,,,,,,,,,
,126.97,2100,2162.4,2417.4,37.9,,,,,,,,,,
,127.14,2163,2162.4,2468.4,36.3,,,,,,,,,,
,127.33,2205,2162.4,2519.4,32.7,,,,,,,,,,
,127.50,2268,2162.4,2550.0,29.6,,,,,,,,,,
,127.67,2310,2162.4,2570.4,27.6,,,,,,,,,,
,127.86,2352,2162.4,2570.4,25.6,,,,,,,,,,
,128.03,2415,2162.4,2570.4,22.5,,,,,,,,,,
,128.20,2457,2162.4,2570.4,19.7,,,,,,,,,,
,128.39,2520,2162.4,2570.4,16.2,,,,,,,,,,
,128.56,2562,2162.4,2570.4,15.0,,,,,,,,,,
,128.73,2625,2162.4,2539.8,17.4,,,,,,,,,,
,128.92,2646,2162.4,2499.0,17.4,,,,,,,,,,
,129.09,2709,2162.4,2448.0,17.8,,,,,,,,,,
,129.26,2751,2162.4,2417.4,16.6,,,,,,,,,,
,129.45,2793,2162.4,2386.8,16.2,,,,,,,,,,
,129.62,2835,2162.4,2376.6,15.4,,,,,,,,,,
,129.79,2877,2162.4,2366.4,15.4,,,,,,,,,,
,129.98,2940,2162.4,2366.4,15.0,,,,,,,,,,
,130.15,2982,2162.4,2376.6,15.0,,,,,,,,,,
,130.32,3024,2162.4,2376.6,15.0,,,,,,,,,,
,130.50,3045,2162.4,2386.8,15.0,,,,,,,,,,
,130.67,3087,2162.4,2397.0,15.0,,,,,,,,,,
,130.84,3129,2162.4,2397.0,15.0,,,,,,,,,,
,131.03,3171,2162.4,2407.2,15.0,,,,,,,,,,
,131.20,3213,2162.4,2417.4,15.0,,,,,,,,,,
,131.37,3255,2162.4,2417.4,15.0,,,,,,,,,,
,131.56,3297,2162.4,2427.6,15.0,,,,,,,,,,
,131.73,3339,2162.4,2437.8,15.0,,,,,,,,,,
,131.90,3381,2162.4,2458.2,15.0,,,,,,,,,,
,132.09,3423,2162.4,2499.0,15.0,,,,,,,,,,
,132.26,3465,2162.4,2529.6,15.0,,,,,,,,,,
,132.43,3507,2162.4,2550.0,15.0,,,,,,,,,,
,132.62,3570,2162.4,2560.2,15.0,,,,,,,,,,
,132.79,3591,2162.4,2570.4,15.0,,,,,,,,,,
,132.96,3654,2152.2,2570.4,15.0,,,,,,,,,,
,133.15,3696,2152.2,2570.4,15.0,,,,,,,,,,
,133.32,3738,2152.2,2570.4,15.0,,,,,,,,,,
,133.49,3780,2152.2,2570.4,15.0,,,,,,,,,,
,133.68,3822,2152.2,2570.4,15.0,,,,,,,,,,
,133.85,3843,2142.0,2570.4,15.0,,,,,,,,,,
,134.02,3885,2142.0,2570.4,15.0,,,,,,,,,,
,134.21,3927,2131.8,2570.4,15.0,,,,,,,,,,
,134.38,3969,2131.8,2570.4,15.0,,,,,,,,,,
,134.55,3990,2121.6,2570.4,15.0,,,,,,,,,,
,134.73,4032,2111.4,2570.4,15.4,,,,,,,,,,
,134.90,4074,2101.2,2570.4,15.0,,,,,,,,,,
,135.07,4095,2091.0,2570.4,15.0,,,,,,,,,,
,135.26,4137,2080.8,2570.4,15.0,,,,,,,,,,
,135.43,4158,2060.4,2560.2,15.0,,,,,,,,,,
,135.60,4200,2060.4,2560.2,15.0,,,,,,,,,,
,135.79,4221,2040.0,2550.0,15.0,,,,,,,,,,
,135.96,4242,2040.0,2550.0,15.0,,,,,,,,,,
,136.13,4284,2019.6,2539.8,15.0,,,,,,,,,,
,136.32,4305,2009.4,2539.8,15.0,,,,,,,,,,
,136.49,4347,1999.2,2529.6,15.0,,,,,,,,,,
,136.66,4347,1989.0,2519.4,15.0,,,,,,,,,,
,136.85,4389,1978.8,2509.2,15.0,,,,,,,,,,
,137.02,4284,1224.0,2499.0,46.2,,,,,,,,,,
,137.19,3927,1193.4,2346.0,46.6,,,,,,,,,,
,137.38,3423,1193.4,1999.2,51.7,,,,,,,,,,
,137.55,3213,1326.0,1723.8,33.9,,,,,,,,,,
,137.72,3108,1734.0,1591.2,55.6,,,,,,,,,,
,137.91,3087,1917.6,1662.6,42.2,,,,,,,,,,
,138.08,3108,2009.4,1815.6,33.5,,,,,,,,,,
,138.25,3129,2070.6,2009.4,30.8,,,,,,,,,,
,138.44,3129,2101.2,2142.0,29.6,,,,,,,,,,
,138.61,3150,2131.8,2244.0,28.0,,,,,,,,,,
,138.78,3150,2142.0,2305.2,27.6,,,,,,,,,,
,138.96,3171,2152.2,2356.2,27.2,,,,,,,,,,
,139.13,3192,2152.2,2386.8,25.3,,,,,,,,,,
,139.30,3213,2162.4,2397.0,24.1,,,,,,,,,,
,139.49,3213,2162.4,2407.2,22.5,,,,,,,,,,
,139.66,3234,2162.4,2407.2,20.9,,,,,,,,,,
,139.83,3234,2162.4,2407.2,19.7,,,,,,,,,,
,140.02,3255,2162.4,2397.0,17.8,,,,,,,,,,
,140.19,3276,2162.4,2386.8,16.6,,,,,,,,,,
,140.36,3297,2162.4,2386.8,15.0,,,,,,,,,,
,140.55,3297,2162.4,2386.8,15.0,,,,,,,,,,
,140.71,3318,2162.4,2397.0,15.0,,,,,,,,,,
,140.88,3318,2162.4,2407.2,15.0,,,,,,,,,,
,141.08,3339,2162.4,2417.4,15.0,,,,,,,,,,
,141.24,3360,2162.4,2437.8,15.0,,,,,,,,,,
,141.41,3381,2162.4,2458.2,15.0,,,,,,,,,,
,141.60,3402,2162.4,2478.6,15.0,,,,,,,,,,
,141.77,3402,2162.4,2488.8,15.0,,,,,,,,,,
,141.94,3423,2162.4,2499.0,15.0,,,,,,,,,,
,142.13,3444,2162.4,2519.4,15.0,,,,,,,,,,
,142.30,3444,2162.4,2529.6,15.0,,,,,,,,,,
,142.47,3465,2162.4,2539.8,15.0,,,,,,,,,,
,142.65,3486,2162.4,2539.8,15.0,,,,,,,,,,
,142.82,3507,2162.4,2550.0,15.0,,,,,,,,,,
,142.99,3507,2162.4,2550.0,15.0,,,,,,,,,,
,143.18,3528,2162.4,2560.2,15.0,,,,,,,,,,
,143.35,3549,2162.4,2560.2,15.0,,,,,,,,,,
,143.52,3570,2162.4,2570.4,15.0,,,,,,,,,,
,143.71,3591,2162.4,2570.4,15.0,,,,,,,,,,
,143.88,3612,2162.4,2570.4,15.0,,,,,,,,,,
,144.05,3612,2162.4,2570.4,15.0,,,,,,,,,,
,144.24,3633,2162.4,2570.4,15.0,,,,,,,,,,
,144.41,3654,2152.2,2570.4,15.0,,,,,,,,,,
,144.58,3654,2152.2,2570.4,15.0,,,,,,,,,,
,144.77,3696,2152.2,2570.4,15.0,,,,,,,,,,
,144.94,3696,2152.2,2570.4,15.0,,,,,,,,,,
,145.11,3717,2152.2,2570.4,15.0,,,,,,,,,,
,145.30,3717,2152.2,2570.4,15.0,,,,,,,,,,
,145.47,3738,2152.2,2570.4,15.0,,,,,,,,,,
,145.64,3759,2152.2,2570.4,15.0,,,,,,,,,,
,145.83,3780,2152.2,2570.4,15.4,,,,,,,,,,
,146.00,3801,2152.2,2570.4,15.0,,,,,,,,,,
,146.17,3801,2152.2,2570.4,15.0,,,,,,,,,,
,146.36,3822,2152.2,2570.4,15.0,,,,,,,,,,
,146.53,3822,2152.2,2570.4,15.4,,,,,,,,,,
,146.70,3843,2142.0,2570.4,15.0,,,,,,,,,,
,146.89,3843,2142.0,2570.4,15.4,,,,,,,,,,
,147.06,3864,2142.0,2570.4,15.0,,,,,,,,,,
,147.23,3885,2131.8,2570.4,15.0,,,,,,,,,,
,147.41,3906,2131.8,2570.4,15.0,,,,,,,,,,
,147.58,3906,1438.2,2570.4,6.7,,,,,,,,,,
,147.75,3906,1428.0,2560.2,6.7,,,,,,,,,,
,147.94,3885,1387.2,2509.2,6.7,,,,,,,,,,
,148.11,3885,1366.8,2325.6,15.8,,,,,,,,,,
,148.28,3864,1366.8,2070.6,15.8,,,,,,,,,,
,148.47,3864,1366.8,1856.4,18.1,,,,,,,,,,
,148.64,3780,1193.4,1693.2,48.1,,,,,,,,,,
,148.81,3423,1193.4,1570.8,52.1,,,,,,,,,,
,149.00,3024,1183.2,1397.4,66.7,,,,,,,,,,
Coding: 0050071
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 256341 km
Time Indication: 0
Date: 2000.00.00
Time: 16:26:48
Freeze Frame:
RPM: 3864 /min
Speed: 136.0 km/h
Load: 100.0 %
Voltage: 14.36 V
Bin. Bits: 00001000
Coding: 0000176
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 42
Reset counter: 180
Mileage: 256290 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 180
Mileage: 256290 km
Time Indication: 0
Coding: 00000000
Shop #: WSC 04941
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 179
Time Indication: 0
