Boas pessoal
Alguem tem alguma lista de erros do VAGCOM da Ibiza 130 6L?
Porque dá me estes erros e não sei como descobrir o que é:
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 NJ
Component: 1,9l R4 EDC G000SG 7331
Coding: 00102
Shop #: WSC 06402
VCID: 6CDDB5141C90E8E
VSSZZZ6LZ7R190573 SEZ5Z0G3121493
2 Faults Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 35-00 - Electrical Fault
17965 - Charge Pressure Control
P1557 - 35-00 - Positive Deviation
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP.lbl
Part No SW: 6Q0 907 379 AS HW: 6Q0 907 379 AS
Component: ESP 8.0 front H05 0003
Revision: 00000000 Serial number: 00000000000000
Coding: 0000290
Shop #: WSC 15639 784 71510
VCID: 8E195F9C9A4CFAE
Part No: 6Q0 907 379 AS
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 F
Component: 000B BN-SG. 2S36
Coding: 08332
Shop #: WSC 06402
VCID: 3E794F5C3A6CAAE
1 Fault Found:
01314 - Engine Control Module
49-00 - No Communications
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 AE
Component: 0G AIRBAG VW5 0C 0010
Coding: 12359
Shop #: WSC 06401
VCID: 7AF1834C66C446E
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance too High
Address 17: Instruments Labels: 6L0-920-xx3-17.lbl
Part No: 6L0 920 823 H
Component: KOMBIINSTRUMENT AGD V03
Coding: 00105
Shop #: WSC 15609
VCID: 32616B6CFE347EE
1 Fault Found:
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 02QT GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 06402
VCID: F0E52164B0B88CE
1 Fault Found:
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10121
Shop #: WSC 06402
VCID: 6FE7A2182D86136
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00016
Shop #: WSC 06402
VCID: 3D7B4850376AB16
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
Só sei que o segundo da ENGINE é desvio de pressão, agora o resto não faço a minima ideia.
Abc
AAvila
Coding: 00102
Shop #: WSC 06402
2 Faults Found:
Coding: 0000290
No Faults Found
Coding: 08332
Shop #: WSC 06402
1 Fault Found:
Coding: 12359
Shop #: WSC 06401
1 Fault Found:
Coding: 00105
Shop #: WSC 15609
1 Fault Found:
Coding: 00014
Shop #: WSC 06402
1 Fault Found:
Coding: 10121
Shop #: WSC 06402
2 Faults Found:
Coding: 00016
Shop #: WSC 06402
1 Fault Found:
Abc
AAvila
