Infindavel lista de erros...[AJUDA]
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Controller: 038 906 019 NJ
Component: 1,9l R4 EDC G210SG 9810
Coding: 00102
Shop #: WSC 04941
VSSZZZ6LZ8R110197 SEZ5Z0GN201644
No fault code found.
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 AS
Component: ESP 8.0 front H05 0003
Coding: 0002338
Shop #: WSC 04941
Address 08 -------------------------------------------------------
Controller: 6L0 820 043 E
Component: CLIMAtronic PQ24 3805
Coding: 0000000
Shop #: WSC 00000
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 F
Component: 000B BN-SG. 2S36
Coding: 08588
Shop #: WSC 04941
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 823 H
Component: KOMBIINSTRUMENT AGD V04
Coding: 00105
Shop #: WSC 00000
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 0305 GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 04941
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10181
Shop #: WSC 04941
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00016
Shop #: WSC 04941
1 Fault Found:
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
Address 56 -------------------------------------------------------
Controller: 6L0 035 186 C
Component: seat s04 GRO 6 37
Coding: 00401
Shop #: WSC 04941
End -------------------------------------------------------
Tenho esta infindavel e inexplicavel lista de erros alguém me pode ajudar a traduzilo é que nao sei puto deles!Tenho uma ideia mas nao ao certo!
Fiz clear codes e eles continuam lá.Cm apagalos?
Sei que alguns não são mas o que não dizem fault code...:whistle:
Que andas-te a alterar na parte electrica do carro ultimamente?
Isso é so erros apartir do modulo 9 ou seja o 1 - Engine continua do assu :finga:
Direcção mais precisa 10181
Mais injecção de gasoleo ao peggar 32728
E aumentar um pouco o relantin.
Mais nada...:whistle:
