Erros vag-com SUGESTÕES E PROBLEMAS
Boas amigos.
Aqui vai uma ajudinha:
Error table for VAG Com
This table contains:
2200 error numbers/- texts
and additionally
all 85 different error kinds
The error messages are arranged according to error characteristic numbers with 5 digits and from the following ranges:
01 - Engine electronics
02 - Transmission electronics
03 - Brake electronics (ABS/EDS, ASR, ESP)
08 - Climatic/heater electronics
09 - Electronic central electrical connection
12 - Clutch electronics
15 - Airbag
16 - Steering wheel electronics
17 - Instrument panel employment
18 - / standheizung
19 - Diagnostic interface for data bus
22 - All wheel electronics
24 - Drive slip regulation
25 - Going away barrier
26 - Electrical roof manipulation
34 - Level regulation
35 - Zentralverriegelung
36 - Seat adjustment driver's side
37 - Navigation
45 - Interior monitoring
46 - Central module comfort system
55 - Automatic shining width adjustment (xenon)
56 - Radio
65 - Tire pressure monitoring
66 - Seat/mirror adjustment
76 - A park assistance
and some further.......
And for the following vehicles:
Volkswagen: Lupo 6E, 6X; Polo 6N, 9N; Gulf III, gulf IV; Vento; Bora; Trade wind; Phaeton;
Touareg; Sharan; T4 and Beetle
AUDI: 80 B4; 100 C4; A2; A3 8L, S3; A4, S4; A6, S6, S6 plus;
A8 4D, S8; TT, TT roadster; Coupè, Cabrio Cabriolet; Allroad quattro
Seat: Arosa; Ibiza; Cordoba; Leon; Toledo; Alhambra
Skoda: Fabia; Felicia; Oktavia; Superb
Ford: Galaxy
and further..........
Error characteristic numbers/texts:
00000 no error recognized
00001 braking expensive equipment
00002 transmission expensive equipment
00003 controller
00004 controller for gas operation -J659
00016 actuator floor space/Defrostklappe in the back on the right of -V195
00017 actuator floor space/Defrostklappe at the rear left -V196
00018 actuator cold flap -V197
00019 actuator warm flap -V198
00020 actuator shut-off valve Defrost and Mannanstroemer on the right of -V199
00021 actuator shut-off valve Defrost and Mannanstroemer on the left of -V200
00022 actuator warm flap center console in the back on the right of -V201
00023 actuator warm flap center console at the rear left -V202
00024 actuator cold flap center console in the back on the right of -V203
00025 actuator cold flap center console at the rear left -V204
00026 actuator verteilklappe Defrost or Mannanstroemer on the right of -V205
00027 actuator verteilklappe Defrost or Mannanstroemer on the left of -V206
00028 actuator Design screen on the left of -V207
00029 actuator Design screen center -V208
00030 actuator Design screen on the right of -V209
00031 tracers Defrost at the rear left -E299
00032 tracers Defrost in the back on the right of -E300
00033 tracers outlets in front on the left of -E301
00034 tracers outlets in front center on the left of -E302
00035 tracers outlets in front center on the right of -E303
00036 tracers outlets in front on the right of -E304
00037 tracers for temperature difference floor space/head area -E305
00038 tracers outlet center console at the rear left -E306
00039 tracers outlet center console in the back on the right of -E307
00040 tracers for safety device for children -E318
00041 actuator for indirect ventilation flap -V213
00042 lamp for side marker light on the left of -M43
00043 lamp for side marker light on the right of -M44
00044 control member test group 1 accomplish
00045 control member test group 2 accomplish
00046 engine for stroke nozzle headlamp wash/wipe system, on the left of -V248
00047 engine for stroke nozzle headlamp wash/wipe system, on the right of -V249
00048 temperature sensors heat exchangers on the left of -G306
00049 temperature sensors heat exchangers on the right of -G307
00050 temperature sensors evaporator -G308
00051 temperature sensors floor space at the rear left -G309
00052 temperature sensors floor space in the back on the right of -G310
00053 temperature sensors center console at the rear left -G311
00054 temperature sensors center console in the back on the right of -G312
00055 engine for safety device for children at the rear left -V142
00056 blower engine for temperature sensors inside -V210
00057 actuator shut-off valve b-column and floor space on the right of -V211
00058 relays for heating wiper resting position -J582
00059 clamp 30 for interior lighting
00060 lamps for fog headlights
00061 floor space lights
00062 function requirement chassis
00063 switches for backup lights -F4
00064 actuator for shut-off valve b-column and floor space on the left of -V212
00065 heating element in the floor space at the rear left -Z42
00066 heating element in the floor space in the back on the right of -Z43
00067 consumers 1
00068 consumers 2
00069 engine for safety device for children in the back on the right of -V143
00070 tension starting battery
00071 tracers for fog headlight -E315
00072 tracers for fog tail light -E314
00073 tracers for glove subject -E316
00074 safety device for plug socket 1 -S184
00075 safety device for plug socket 2 -S185
00076 safety device for plug socket 3 -S281
00077 limit switches for windshield wiper -F229
00078 isolating relays 2.Batterie -J7
00079 switches for interior lighting -E317
00080 function requirement sun roof
00081 undervoltage disconnection seat heating
00082 clamp 61 for generator
00083 advance fuel pump
00084 reverse current relays for electrical system battery -J579
00085 reverse current relays for starting battery -J580
00086 relays for parallel connection batteries -J581
00087 clamp 30 for startingrelevant consumers
00088 load monitoring for starting battery
00089 line monitoring for clamp 30 starting battery
00090 supply line clamp 30 starting battery
00091 signal ignition key puts
00092 temperature sensors starting battery -G331
00093 clamp 15 for startingrelevant consumers
00094 engine for zentralverriegelung, door at the rear left, LOCK -V214
00095 engine for zentralverriegelung, door in the back right, LOCK -V215
00096 engine for zentralverriegelung, driver's door-save -V161
00097 engine for zentralverriegelung, passenger door-save -V162
00098 engine for zentralverriegelung, door in the back left-save -V163
00099 engine for zentralverriegelung, door in the back right-save -V164
00100 tracers for support rod, driver's side -E308
00101 tracers for support rod, front seat passenger side -E309
00102 tracers for support rod, at the rear left -E310
00103 tracers for support rod, in the back on the right of -E311
00104 tracers for gas cap unblocking -E319
00105 signal zentralverriegelung SAVE/LOCK driver's side
00106 signal zentralverriegelung SAVE/LOCK front seat passenger side
00107 signal zentralverriegelung SAVE/LOCK at the rear left
00108 signal zentralverriegelung SAVE /LOCK in the back right
00109 lamp for mirror turn signal driver's side -L131
00110 lamp for mirror turn signal front seat passenger side -L132
00111 control lamp for support rod, driver's side -K174
00112 control lamp for support rod, front seat passenger side -K175
00113 control lamp for support rod, at the rear left -K176
00114 control lamp for support rod, in the back on the right of -K177
00115 tracers for telephone connection front seat passenger side -E320
00116 tracers for telephone connection at the rear left -E321
00117 tracers for telephone connection in the back on the right of -E322
00118 tracers for Defrost driver's side -E323
00119 tracers for Defrost front seat passenger side -E324
00120 external warning lamp/door door light driver's side
00121 external warning lamp/door door light front seat passenger side
00122 external warning lamp/door door light at the rear left
00123 external warning lamp/door door light in the back right
00124 line for communication door expensive device tightening assistance driver's side
00125 line for communication door expensive device tightening assistance front seat passenger side
00126 line for communication door expensive device tightening assistance at the rear left
00127 line for communication door expensive device tightening assistance in the back right
00128 control lamp for telephone connection front seat passenger side -K178
00129 lighting for door interior grasp at the rear left -L133
00130 lighting for door interior grasp in the back on the right of -L134
00131 door external grasp lighting/spiegelleuchte driver's side
00132 door external grasp lighting/spiegelleuchte front seat passenger side
00133 door external grasp lighting/spiegelleuchte at the rear left
00134 door external grasp lighting/spiegelleuchte in the back right
00135 givers for wheel acceleration in front on the left of -G337
00136 givers for wheel acceleration in front on the right of -G338
00137 givers for wheel acceleration at the rear left -G339
00138 givers for wheel acceleration in the back on the right of -G340
00139 givers for body acceleration in front on the left of -G341
00140 givers for body acceleration in front on the right of -G342
00141 givers for body acceleration in the back -G343
00142 valve for absorption adjustment in front on the left of -N336
00143 valve for absorption adjustment in front on the right of -N337
00144 valve for absorption adjustment at the rear left -N338
00145 valve for absorption adjustment in the back on the right of -N339
00146 supply voltage for givers for acceleration in front right/at the rear left
00147 supply voltage for givers for acceleration in front left/in the back right
00148 potential transformers for starting battery charge -A15
00149 no tape end programming takes place
00150 plausibility brake booster system
00151 plausibility addr system
00152 controller for windshield wiper motor front seat passenger side -J584
00153 windshield wiper motor driver's side -V216
00154 windshield wiper motor front seat passenger side -V217
00155 communication of controllers driver's side front seat passenger side
00156 control for disk washer pump
00157 clamp X
00158 function requirement Dimmstufe increases
00159 function requirement Dimmstufe reduce
00160 adaptation brake booster
00161 systematical test brake booster
00162 adjustment controller for braking force reinforcement does not take place
00163 controller for braking force reinforcement learns operating points
00164 controller for battery monitoring -J367 in the emergency operation
00165 switches for transmission position P/N
00166 switches for entrance and starting authorization -E415
00167 keys 5
00168 keys 6
00169 keys 7
00170 keys 8
00171 keys 1 not learned
00172 keys 2 not learned
00173 keys 3 not learned
00174 keys 4 not learned
00175 keys 5 not learned
00176 keys 6 not learned
00177 keys 7 not learned
00178 keys 8 not learned
00179 antenna driver's side for entrance and starting authorization -R134
00180 antenna front seat passenger side for entrance and starting authorization -R135
00181 antenna bumper in the back for entrance and starting authorization -R136
00182 antenna trunk for entrance and starting authorization -R137
00183 antenna -1 interior for entrance and starting authorization -R138
00184 control for tracers engine start/stop
00185 control relay for voltage supply clamp 15
00186 control relay for voltage supply clamp 15SV
00187 control relay for voltage supply clamp 75X
00188 control 1 relay for voltage supply clamp 50
00189 control 2 relays for voltage supply clamp 50
00190 sensor for contact, door external grasp driver's side -G415
00191 sensor for contact, door external grasp front seat passenger side -G416
00192 sensor for contact, door external grasp at the rear left -G417
00193 sensor for contact, door external grasp in the back on the right of -G418
00194 ignition key departure barrier
00195 voltage supply for potentiometer inside mirror
00196 potentiometers horizontal for inside mirror -G353
00197 potentiometers vertically for inside mirror -G354
00198 EC mirrors in the inside mirror -Y7
00199 tracers for interior light in front -E326
00200 tracers for interior light in the back -E327
00201 tracers for read light in front -E328
00202 tracers for read light in the back -E329
00203 switches for sun roof -E8
00204 tracers for sun roof -E325
00205 control lamp for garage gate opener -K179
00206 control engines for inside mirrors
00207 heating for givers for air humidity -N340
00208 clamp 30 for glove specialized lighting
00209 clamp 30 for make-up mirrors
00210 control for interior lights in front
00211 control for interior lights in the back
00212 control for reading lights in front left
00213 control for reading lights in front right
00214 control for reading lights at the rear left
00215 control for reading lights in the back right
00216 signal EC mirror light up
00217 supply voltage for givers for air humidity
00218 givers for air humidity -G355
00219 loading level actively
00220 connection to the sun roof
00221 connection to the interior monitoring
00222 connection to the rain sensor
00223 control lamp for givers for vehicle inclination -K188
00224 ejectors for tail bonnet lock stretch
00225 ejectors for tail bonnet lock ease
00226 control lamp for absorption adjustment -K189
00227 tracers for absorption adjustment -E387
00228 tracers for level regulation -E388
00229 refrigerant pressure
00230 switches for transmission position P -F305
00231 wrong engine data set
00232 wrong transmission data record
00233 sensor for automatic distance regulation erfassungsbereich blocks
00234 sensor for automatic distance regulation adjusts
00235 tracers for automatic distance regulation -E357
00236 Antenne2 for interior for entrance and starting authorization -R139
00237 single solenoid valve for ABS in front on the left of -N59
00238 single solenoid valve for ABS in front on the right of -N58
00239 single solenoid valve for ABS at the rear left -N57
00240 single solenoid valve for ABS in the back on the right of -N56
00241 pressure control valve for anti-slip -N238
00242 valve for engine throttling -N237
00243 exhaust brake
00244 supply voltage for ABS valves in front right + at the rear left
00245 supply voltage for ABS valves in front left + in the back right
00246 mass for ABS valves in front right + at the rear left
00247 mass for ABS valves in front left + in the back right
00248 switches for transmission -E206
00249 function feedback automatic controller for circulating air blowers
00250 switches for area enterprise -E207
00251 givers 4 for fuel supply -G393
00252 SBBR light at the rear left
00253 SBBR light in the back right
is missing to 00254 anti-slip attitude
00255 valves for ABS
00256 givers for refrigerant pressure/temperature -G395
00257 intake valve ABS in front on the left of -N101
00258 single solenoid valve 1 -N88
00259 intake valve ABS in front on the right of -N99
00260 single solenoid valve 2 -N89
00261 intake valve ABS in the back -N103
00262 single solenoid valve 3 -N90
00263 transmissions
00264 single solenoid valve 4 -N91
00265 exhaust valve ABS in front on the left of -N102
00266 single solenoid valve 5 -N92
00267 exhaust valve ABS in front on the right of -N100
00268 single solenoid valve 6 -N93
00269 exhaust valve ABS in the back -N104
00270 single solenoid valve 7 -N94
00272 function disconnection by electromagnetic disturbances
00273 intake valve ABS in the back on the right of -N133
00274 intake valve ABS at the rear left -N134
00275 exhaust valve ABS in the back on the right of -N135
00276 exhaust valve ABS at the rear left -N136
00277 in/exhaust valve ABS in front on the left of -N137
00278 main valve ABS -N105
00279 valve 1 for differential lock -N125
00280 valve 2 for differential lock -N126
00281 givers for driving speed -G68
00282 butterfly valve plates -V60
00283 speed pickups in front on the left of -G47
00284 in/exhaust valve ABS in front on the right of -N138
00285 speed pickups in front on the right of -G45
00286 in/exhaust valve ABS at the rear left -N139
00287 speed pickups in the back on the right of -G44
00288 control member for steering column bolting device -N360
00289 in/exhaust valve ABS in the back on the right of -N140
00290 speed pickups at the rear left -G46
00291 Druckschalter-F116/warning contact -F117
00292 hydraulic power supply pressure level
00293 multi-function switches -F125
00294 push button switches 1 for transmission condition
00295 push button switches 2 for transmission condition
00296 kick-down switches -F8
00297 givers for transmission speed -G38
00298 switches for differential lock -E121
00299 program switches -E122
00300 givers for transmission oil temperature -G93
00301 scavenger pump for ABS -V39
00302 relays for single solenoid valves ABS -J106
00303 Funktionswahlschalter-E91
00304 control automatic controller for fresh air blowers
00305 fuel consumption indicator signal
00306 secondary air system zylinder-Reihe 1
00307 secondary air system zylinder-Reihe 2
00308 supply voltage engines sun roof/Rolo sun roof
00309 dosing pump for cleaning agent -V135
00310 temperature sensors 1 for catalyst -G20
00311 tire filler connector
00312 temperature sensors 2 for catalyst -G132
00313 catalyst
00314 two-way valve for recycling of exhaust gases -N161
00315 connection to the Rolo for sun roof
00316 lamps for tail lighting
00317 controller for rear flap -J605
00318 supply voltage for controller for rear flap
00319 engine for rear flap hydraulics -V241
00320 valve for rear flap hydraulics -N346
00321 givers for rear flap hydraulics -G383
00322 switches for deactivation interior monitoring -E267
00323 givers for vehicle inclination -G384
00324 tracers for deactivation giver for vehicle inclination -E360
00325 tracers for back window opening -E361
00326 switches for emergency shut-down theft alarm system -E362
00327 signal sun roof open
00328 control for unblocking back window
00329 control for unblocking rear flap
00330 signal tail wiper interval
00331 signal tail wiper wiping wash
00332 control for tank flap
00333 control for relays for tightening assistance
00334 control heatable back window stage 2
00335 control tail lights
00336 control lighting tail
00337 control lighting driver's door
00338 control lighting passenger door
00339 control lighting door at the rear left
00340 control lighting door in the back right
00341 control rear flap UP
00342 control rear flap TOO
00343 control rear flap lock swing out
00344 control rear flap lock swing
00345 control rear flap lock unlock
00346 control rear flap lock lock
00347 single solenoid valve 8 -N281
00348 single solenoid valve 9 -N282
00349 single solenoid valve 10 -N283
00350 mass feedback of modulation valves
00351 givers for number of revolutions intermediate shaft -G265
00352 clamp 30A
00353 function feedback automatic controller for fresh air blowers
00354 potential transformers windshield heating -A18
00355 actuator for Mannanstroemer in front on the left of -V237
00356 actuator for Mannanstroemer in front on the right of -V238
00357 control automatic controller for circulating air blowers
00358 control for cooling agent stop valve
00359 temperature sensors Mannanstroemer in front on the left of -G385
00360 temperature sensors Mannanstroemer in front on the right of -G386
00361 heating element for additional heating system -Z35
00362 actuator for amount of air flap at the rear left -V239
00363 actuator for amount of air flap in the back on the right of -V240
00364 clamp 15 Slave
00365 line for communication interior monitoring entrance
00366 line for communication interior monitoring exit
00367 absorbers in front left softly
00368 absorbers in front left hard
00369 absorbers in front right softly
00370 absorbers in front right hard
00371 absorbers at the rear left softly
00372 absorbers at the rear left hard
00373 absorbers in the back right softly
00374 absorbers in the back right hard
00375 control issuing window left open
00376 control issuing window left closes
00377 control issuing window right open
00378 control issuing window right closes
00379 clamp 58s
00380 controller for special vehicles -J608
00381 data bus combination instrument
00382 fuzes for Kopfairbag in the back, driver's side -N343
00383 fuzes for Kopfairbag in the back, front seat passenger side -N344
00384 optical data bus
00385 plus exit audio channel for language/telephone
00386 minus exit audio channel for language/telephone
00387 plus exit audio channel for navigation announcements
00388 minus exit audio channel for navigation announcements
00389 headphone exit 1, left channel
00390 headphone exit 1, right channel
00391 headphone exit 2, left channel
00392 headphone exit 2, right channel
00393 display test, black segments
00394 display test, white segments
00395 display test, red segments
00396 display test, green segments
00397 display test, blue segments
00398 finding lighting
00399 lighting function feedback
00400 turn signals, acoustic feedback
00401 acoustic signal generator
00402 heating element for air additional heating system -Z35
00403 engine for sun roof -V1
00404 engine for sun roof, in the back -V146
00405 engine for rollo sun roof -V260
00406 resounding givers for engine for sun roof -G402
00407 resounding givers engine for sun roof, in the back -G403
00408 resounding givers for engine for Rolo sun roof -G404
00409 switches for sun roof, signal of the emergency tracer lines up continuously
00410 preselection signal for sun roof opening
for rollo lines up to 00411 signal of the tracer continuously
00412 comfort CAN_L line
00413 comfort CAN_H line
00414 CAN_L - Line
00415 CAN_H - Line
00416 thermal protection engine for sun roof
00417 central low clay/tone loudspeakers in front on the left of -R101
00418 central low clay/tone loudspeakers in front on the right of -R102
00419 central clay/tone loudspeakers in front on the left of -R103
00420 central clay/tone loudspeakers in front on the right of -R104
00421 central clay/tone loudspeakers at the rear left -R105
00422 central clay/tone loudspeakers in the back on the right of -R106
00423 thermal protection engine for Rolo sun roof
00424 clock control of the givers for a park assistance
00425 function test of the announcements for a park assistance
00426 control lamp for stability program -K155
00427 wiring test of the givers for a park assistance
00428 function test of the givers for a park assistance
00429 announcement for a park assistance in front on the left of -Y13
00430 announcement for a park assistance in front on the right of -Y14
00431 announcement for a park assistance in the back -Y15
00432 supply voltage for announcements and buzzer a park assistance
00433 tracers for a park assistance -E266
00434 givers for a park assistance in front left inside -G332
00435 givers for a park assistance in front right inside -G333
00436 givers for a park assistance at the rear left inside -G334
00437 givers for a park assistance in the back right inside -G335
00438 givers 2 for fuel supply -G169
00439 givers 3 for fuel supply -G237
00440 givers for fuel supply auxiliary tank -G292
00441 givers for schwimmerstand fuel supply auxiliary tank -G293
00442 clamp 87F fuel pump
00443 safety device fuel pump auxiliary tank -S266
00444 control fuel pump auxiliary tank
00445 loss of refrigerant
00446 function restriction by undervoltage
00447 function restriction by overvoltage
00448 citation pump for Haldexkupplung -V181
00449 citation pump on
00450 citation pump out
00451 all wheel clutch separately
00452 all wheel clutch closed
00453 function restriction by temperature rise
00454 all wheel monitoring
00455 controller for entrance and starting authorization at the comfort CAN -J518
00456 controller for entrance and starting authorization -J518
00457 controller for electrical system -J519
00458 controller for battery monitoring -J367
00459 controller, announcement and control unit for information, in front -J523
00460 controller, announcement and control unit for information, in the back -J524
00461 controller for seat adjustment with MEMORY, front seat passenger -J521
00462 controller for seat adjustment with MEMORY, in the back -J522
00463 controller for digital sound-pack -J525
00464 controller with display unit for radio and navigation -J503
00465 controller for telephone/telematics -J526
00466 controller for steering column electronics -J527
00467 TV tV-Tuner -R78
00468 CD-ROM drive assembly -R92
00469 data bus display/Infotainment in the single-wire enterprise
00470 company data bus comfort in the single-wire enterprise
00471 controller for EGD electronically regulated absorption -J250
00472 controller for braking force reinforcement -J539
00473 controller for electrical park/Handbremse-J540
00474 controller for going away barrier -J334
00475 controller for sliding door -J558
00476 controller for fuel pump -J538
00479 controller for remote maintenance central bolting device -J276
00480 controller in the instrument panel employment -J285, at the Infotainment CAN
00481 controller for traffic radio -J559
00482 display unit for TV and video, in the back -R97
00483 controller for air additional heating system
00484 controller for vehicle situation layer -J603
00485 tracers for zentralverriegelung, door external grasp driver's side -E369
00486 tracers for zentralverriegelung, door external grasp front seat passenger side -E370
00487 tracers f.Zentralverriegelung, door external grasp at the rear left -E371
00488 tracers for zentralverriegelung, door external grasp in the back on the right of -E372
00489 givers for leaking out temperature at the rear left -G405
00490 givers for leaking out temperature in the back on the right of -G406
00491 allocation of the speed pickups at the controller examine
00492 body angles of pitch of the controller for level control
00493 ESP Sensoreinheit -G419
00494 ESP Sensoreinheit, wrong construction unit
00495 ESP Sensoreinheit, supply voltage
00496 givers for vehicle level in front
00497 givers for vehicle level in the back
00498 travel writers -G24
00499 announcement for on-board tension -Y11
00500 announcement for oil temperature -Y12
00501 control lamp for oil level -K38
00502 control lamp for going away barrier -K115
00503 control of valves pump/nozzle
00504 valve for pump/nozzle cylinder 1 -N240
00505 valve for pump/nozzle cylinder 2 -N241
00506 valve for pump/nozzle cylinder 3 -N242
00507 valve for pump/nozzle cylinder 4 -N243
00508 valve for pump/nozzle cylinder 5 -N244
00509 valve for pump/nozzle cylinder 6 -N245
00512 resounding givers not on reference mark
00513 givers for engine speed -G28
00514 givers for ignition -G4
00515 resounding givers -G40
00516 throttle idle microswitches -F60
00517 full load switches -F81
00518 butterfly valve potentiometers -G69
00519 givers for suction tube pressure -G71
00520 air mass/amount of air measurers -G70/-G19
00521 CO potentiometers -G74
00522 givers for coolant temperature -G62
00523 givers for intake air temperature -G42
00524 knocking sensor 1 -G61
00525 Lambdasonde -G39
00526 Bremslichtschalter f
00527 givers for suction tube temperature -G72
00528 elevator givers -F96
is missing to 00529 number of revolutions information
00530 butterfly valve placing he/potentiometers -G88
00531 air mass measurers reference tension
00532 supply voltage
00533 idling regulation
00534 givers for oil temperature -G8
00535 first knocking regulation
00536 second knocking regulation
00537 Lambdaregelung
00538 reference tension
00539 givers for fuel temperature -G81
00540 knocking sensor 2 -G66
00541 potentiometers for schieberweg -G99
00542 givers for needle stroke -G80
00543 number of revolutions after maximum exceeded
00544 load pressure after maximum exceeded
00545 engine/transmission electrical connection
00546 data line defectively
00547 pressure control switches for ABS -F137
00548 voltage supply error memory
00549 fuel consumption signal
00550 spraying beginning regulation
00551 catalyst temperature rise
00552 potentiometers for amount of air measurer -G19
00553 air mass measurers -G70
00554 Lambdaregelung 2
00555 Lambdasonde 2 -G108
00556 potentiometers for recycling of exhaust gases -G212
00557 push button switches power steering -F88
00558 adjusting border metering unit lean
00559 adjusting border metering unit fat
00560 recycling of exhaust gases rule difference
00561 mixture adjustment
00562 givers for oil level/oil temperature -G266
00563 announcement for momentary consumption -Y10
00565 operating and display unit for Climatronic in the back -E265
00566 guidance assistance enterprise
00567 control guidance engine
00568 position sensors in the guidance engine
00569 river guidance engine
00570 relays for guidance engine -J509
00571 guidance coupling
00572 givers for guidance position -G268
00573 givers for guidance moment -G269
00575 suction tube pressure
00576 clamp 15
00577 knocking regulation cylinder 1
00578 knocking regulation cylinder 2
00579 knocking regulation cylinder 3
00580 knocking regulation cylinder 4
00581 knocking regulation cylinder 5
00582 knocking regulation cylinder 6
00583 knocking regulation cylinder 7
00584 knocking regulation cylinder 8
00585 temperature sensors for recycling of exhaust gases -G98
00586 regulation recycling of exhaust gases system
00587 adjusting border metering unit
00588 fuzes for Airbag (driver's side) -N95
00589 fuzes 1 for Airbag (front seat passenger side) -N131
00590 fuzes 2 for Airbag (front seat passenger side) -N132
00591 belt switches driver's side -E24
00592 belt switches front seat passenger side -E25
00593 seat contact switches passenger seat -F151
00594 ignition circle Airbag (driver Airbag, front seat passenger Airbag)
00595 Crashdaten stored
00596 short-circuit between valve lines
00597 different wheel number of revolutions impulses
00598 hydraulic/mechanical error
00599 plausibility push button switch/stop light switch
00600 potentiometers -G92 in the actuator -V68 (for temperature flap)
00601 potentiometers -G112 in the actuator -V70
00602 potentiometers -G114 in the actuator -V85
00603 actuator for floor space /Defrostklappe -V85
00604 potentiometers -G113 in the actuator -V71 (for stagnation pressure flap)
00605 two-way valve for freshness and circulating air flap -N63
00606 two-way valve for cooling agent stop valve -N147
00607 OAT indicators -G106
00608 givers for loading condition -G119
00609 ignition exit 1
00610 ignition exit 2
00611 ignition exit 3
00612 ignition exit 4
00613 ignition exit 5
00614 ignition exit 6
00615 ignition exit 7
00616 ignition exit 8
00617 givers for delay left - Airbag -G104
00618 givers for delay right - Airbag -G105
00619 giver inlet left
00620 giver inlet right
00621 valve for pressure reduction -N155
00622 fuel filters drain
00623 ABS/transmission electrical connection
00624 climatic compressor interference
00625 geschwindigkeitssignal
00626 control lamp for time the glow plugs are on -K29
00627 givers for water level -G120
00628 correcting variable monitoring
00629 brake pedal switches -F47
00631 connection air conditioning system - Motronic
00632 connection Climatronic - combination instrument - interface
00633 lines fuzes/givers for delay
00634 pre-resistor for EDS -N159
00635 heating Lambdasonde before catalyst
00636 givers for acceleration in front on the right of -G121
00637 givers for acceleration at the rear left -G122
00638 engine/transmission electrical connection 2
00639 givers for delay -G123
00640 relays for heating Lambdasonde -J278
00641 ATF temperature
00642 transfer valve EDS in front on the right of -N166
00643 exhaust valve EDS in front on the right of -N167
00644 transfer valve EDS in front on the left of -N168
00645 exhaust valve EDS in front on the left of -N169
00646 ABS ASR/engine electrical connection 1
00647 ABS ASR/engine electrical connection 2
00648 heating Lambdasonde after catalyst
00649 in/exhaust valve ABS in the back -N160
00650 clutch pedal switches -F36
00651 lines for ignition circles
00652 course monitoring
00653 plausibility selector lever/transmission
00654 fuzes for belt-taut (driver's side) -N153
00655 fuzes for belt-taut (front seat passenger side) -N154
00656 seat allocation sensor front seat passenger side -G128
00657 actuator for center outlet -V102
00658 service module
00660 kickdown switches/butterfly valve potentiometers
00661 temperature indication
00662 tachometers
00663 speedometers
00664 fuel quantity indication
00665 control lamp for belt warning -K19
00666 gong
00667 outside temperature signal
00668 on-board tension Kl. 30
00670 givers for butterfly valve plate -G127
00671 switches for GRA -E45
00672 hydraulic pump ABS with pre-resistor
00679 heating Lambdasonde 2 before catalyst
00684 heating Lambdasonde 2 after catalyst
00689 wrong air in the air intake system
00694 lighting switch and instruments
00696 valve for pressure-reducing valves on the left of -N170
00697 valve for pressure-reducing valves on the right of -N171
power input increased 00698 controller
00699 Lambdasonde after catalyst -G130
00700 Lambdasonde 2 after catalyst -G131
00702 givers for fuel composition -G133
00703 no-load operation recognition butterfly valve potentiometer/throttle idle microswitch
00705 relays for radiator exhaust stage 1 -J279
00706 relays for radiator exhaust stage 2 -J513
00707 valve for centre outlets -N236
00709 photo sensor 2 for sun exposure -G134
00710 actuator for Defrostklappe -V107
00711 actuator for floor space flap on the left of -V108
00712 actuator for floor space flap on the right of -V109
00713 actuator for center outlets on the left of -V110
00714 actuator for center outlets on the right of -V111
00715 actuator for rear outlet -V112
00716 actuator for circulating air flap -V113
00717 actuator for AKF flap -V114
00718 switches for nozzle left above -F179
00719 switches for nozzle on the top right -F180
00720 switches for nozzle left down -F181
00721 switches for nozzle right down -F182
00722 switches for nozzle center on the left of -F183
00723 switches for nozzle center on the right of -F184
00724 switches for nozzle rear area on the left of -F185
00725 switches for nozzle rear area on the right of -F186
00726 switches for nozzle rear area center -F187
00727 potentiometers -G135 in the actuator -V107 (for Defrostklappe)
00728 potentiometers -G136 in the actuator -V110 (for center outlets left)
00729 potentiometers -G137 in the actuator -V111 (for center outlets right)
00730 potentiometers -G138 in the actuator -V102 (for center outlets)
00731 potentiometers -G139 in the actuator -V108 (for floor space flap left)
00732 potentiometers -G140 in the actuator -V109 (for floor space flap right)
00733 potentiometers -G141 in the actuator -V112 (for rear outlets)
00734 potentiometers in centre outlet -G142
00735 potentiometers -G143 in the actuator -V113 (for circulating air flap)
00736 potentiometers -G144 in the actuator -V114 (for AKF flap)
00737 valve for heating regulation on the left of -N175
00738 valve for heating regulation on the right of -N176
00739 pump for coolant circulation -V50
00740 givers for cylinder 1 recognition -G145
00741 brake pedal monitoring
00742 driving battery ventilation system
00743 givers for battery ventilation -G146
00744 driving battery temperature control
00745 isolation monitoring
00746 driving battery cell loss
00747 givers for battery temperature in front -G52
00748 givers for battery temperature in the back -G53
00749 ventilation flap
00750 error lamp
00751 capacity announcement driving battery
00752 exhausts and battery heating
00753 electrical connections of wheel number of revolutions impulses
00754 hot light
00755 control lamp for oil pressure -K3
00756 givers for leaking out temperature on the left of -G150
00757 givers for leaking out temperature on the right of -G151
00758 secondary air system
00759 adjusters for leaking out temperature on the left of -G155
00760 adjusters for leaking out temperature on the right of -G156
00761 errors in the engine expensive equipment stored
00762 einspritzventil -N181
00763 givers for gas pressure (driver's side) -G147
00764 givers for gas pressure (front seat passenger side) -G148
00765 givers for rule slidegate valve way -G149
00766 givers for leaking out temperature -G152
00767 givers for evaporator temperature in the back -G153
00768 givers for heat exchanger temperature in the back -G154
00769 givers coolant temperature engine exit -G82
00770 givers coolant temperature radiator exit -G83
00771 givers for fuel quantity indication g
00772 oil pressure switches -F22
00773 givers for oil pressure -G10
00774 givers for vehicle level HL -G76
00775 givers for vehicle level HR -G77
00776 givers for vehicle level VL -G78
00777 givers for position of the gas pedal -G79
00778 givers for guidance angle -G85
00779 temperature sensors for outside temperature -G17
00780 givers for vertical acceleration -G90
00781 actuator in front on the left of -V76
00782 actuator in front on the right of -V77
00783 actuator at the rear left -V78
00784 actuator in the back on the right of -V79
00785 temperature sensors - instrument panel -G56
00786 temperature sensors - roof -G86
00787 temperature sensors - fresh air suction port -G89
00788 two-way valve floor space Defrostklappe -N118
00789 switches for reverse movement -F41
00790 freshness/circulating air flap
00791 thermal relays for evaporator -E33
00792 push button switches for air conditioning system -F129
00793 givers for brake pedal position -G100
00794 givers for hydraulic pump -G101
00795 givers for vertical acceleration in the back -G102
00796 blowers for temperature sensor -V42 (instrument panel)
00797 photo sensor for sun exposure -G107
00799 givers for coolant temperature -G110
00800 temperature sensors - fresh air blower -G109
00801 high pressure switches for magnetic clutch -F118
00802 low pressure switches for air conditioning system -F73
00803 givers for spring travel in front on the right of -G116
00804 givers for spring travel in front on the left of -G115
00805 valve for shock strut VL -N148
00806 valve for shock strut VR -N149
00807 valve for shock strut HL -N150
00808 valve for shock strut HR -N151
00809 brake boosters ESP
00810 givers 1/2 (- G201/-G214) for brake pressure
00811 system not query ready
00812 release switches for solenoid coil for brake pressure -F841
00813 givers 2 for brake pressure -G214
00814 solenoid coil for brake pressure -N247
00815 switches for brake recognition -F238
00816 givers for guidance assistance -G250
00817 guidance assistance temperature protection
00818 givers for leaking out temperature evaporator -G263
00819 high pressure givers -G65
00820 switches for brake recognition -F83
00821 antenna 2 for radio -R93
00822 connection of the digital sound package to the radio
00823 LINE exit in front left
00824 control lamp for ASR -K86
00825 heatable driver's seat -Z6
00826 heatable passenger seat -Z8
00827 relays for exhausts for cooling agent -J26
00828 relays for 3-te stage exhaust cooling agent -J135
00829 controller for heating -J162
00830 controller for manipulationmanipulation manipulation -J256
00831 controller for exhausts for cooling agent, stage 1+2 -J293
00832 Bedienungs-und display unit -E87
00833 signal for control heatable windshield
00834 signal for control heatable back window
00835 connection to the controller for manipulationmanipulation manipulation
00836 valve 1 for gangwahl -N284
00837 valve 2 for gangwahl -N285
00838 valve 3 for gangwahl -N286
00839 valve 4 for gangwahl -N287
00840 relays for hydraulic pump transmission -J510
00841 givers for hydraulic pressure transmission -G270
00842 controller for electronic transmission
00843 potentiometers for selector levers forwards/back -G272
00844 switches for lane recognition selector lever -F257
00845 switches for n-recognition selector lever -F258
00846 switches stop recognition selector lever -F259
00847 relays for consumer disconnection -J511
00848 switches for starting/stop enterprise -E262
00849 s-contact at the ignition starting switch D
00850 tax exit active amplifier at the radio
00851 loudspeakers
00852 loudspeakers in front
00853 loudspeakers in the back
00854 exit radio display instrument panel employment
00855 connection to CD change-over switch
00856 antenna at the radio
00857 CD change-over switches -R41
00858 connection ZF exit radio to the antenna amplifier
00859 LINE exit in front right
00860 LINE exit at the rear left
00861 connection to the computer for navigation
00862 antenna for navigation (government inspection department) -R50/-R52
00863 antenna 1 for TV -R55
00864 antenna 2 for TV -R56
00865 antenna 3 for TV -R57
00866 antenna 4 for TV -R58
00867 connection to the ABS controller
00868 angle of rotation sensor -G208
00869 LINE exit in the back right
00870 low clay/tone loudspeakers in front on the left of -R21
00871 low clay/tone loudspeakers in front on the right of -R23
00872 low clay/tone loudspeakers at the rear left -R15
00873 low clay/tone loudspeakers in the back on the right of -R17
00874 hochtonlautsprecher in front on the left of -R20
00875 hochtonlautsprecher in front on the right of -R22
00876 hochtonlautsprecher at the rear left -R14
00877 hochtonlautsprecher in the back on the right of -R16
00878 connections to loudspeakers VL
00879 connections to loudspeakers VR
00880 connections to loudspeakers at the rear left
00881 connections to loudspeakers in the back right
00882 service module for program selection -E200
00883 ignitionstarterswitchingground (clamp S)
00884 ignitionstarterswitchingground (clamp X)
00885 ignitionstarterswitchingground (clamp 50)
00886 turn signal switches -E2
00887 tracers for warning light -E229
00888 windshield wiper switches for interval enterprise -E22
00889 signalhornbetaetigung h
00890 tracers for heatable back window -E230
00891 tracers for remote unblocking, rear flap -E233
00892 tracers for unblocking/rear flap lockcylinder -F248
00893 tracers unblocking/rear flap grasp -E234
00894 tracers for heating outside mirror -E231
00895 GRA/addr operating sector -E45
00896 closing unit rear flap -F256
00897 disk washer pump -V5
00898 control climatic compressor
00899 safety device for wiper engine -S128
00900 safety device horn/double clay/tone horn -S194
00901 backup lights
00902 safety device for remote unblocking, rear flap -S195
00903 safety device for heating, outside mirror -S196
00904 safety device magnet for selector lever barrier -S197
00905 safety device for backup lights -S40
00906 horn/double clay/tone horn -H1
00907 interference load management
00908 controller for wiper engine
00909 windshield wiper motor v (stage 1/2)
00910 control lamp for hazard warning flasher -K6
00911 control lamp heatable back window -K10
00912 switches for window lifter VL -E40
00913 switches for window lifter VR, driver's side -E81
00914 switches for window lifter HL, driver's side -E53
00915 switches for window lifter HR, driver's side -E55
00916 check switches for window lifters in the back -E39
00917 automatic controllers for windshield wiper controlled cycle switching
00918 clamp 31
00919 engine for rear windshield wiper -V12
00920 heatable outside mirrors (Z4/Z5)
00921 control lamp heatable outside mirrors -K153
00922 windshield wiper switches for interval enterprise -E22 (stage 1)
00923 windshield wiper switches for interval enterprise -E22 (stage 2)
00924 relays for headlamp wash/wipe system -J39
00925 safety device (30) for interior lights -S261
00926 clamp 30
00927 clamp 30 right
00928 closing unit for zentralverriegelung driver's side -F220
00929 closing unit for zentralverriegelung front seat passenger side -F221
00930 closing unit for zentralverriegelung HL -F222
00931 closing unit for zentralverriegelung HR -F223
00932 engine window lifter driver's side -V147
00933 engine window lifter front seat passenger side -V148
00934 engine window lifter HL -V26
00935 engine window lifter HR -V27
00936 switches window lifter front seat passenger side -E107
00937 switches window lifter HL -E52
00938 switches window lifter HR -E54
00939 engines mirror adjustment driver's side -V149
00940 engines mirror adjustment front seat passenger side -V150
00941 engine mirror folding driver's side -V121
00942 engine mirror folding front seat passenger side -V122
00943 heatable outside mirror driver's side -Z4
00944 heatable outside mirror front seat passenger side -Z5
00945 Crashsensor for Frontairbag -G190
00946 interior light w
00947 switches remote unblocking rear flap -E188
00948 signal sun roof closes
00949 engine for zentralverriegelung rear flap -V53, LOCK
00950 engine for zentralverriegelung rear flap -V53, UNLOCK
00951 relays for engine remote unblocking rear flap -J398
00952 signal driver's door openly
00953 zeitbegrenzung interior light
00954 interlock relays for starter -J433
00955 keys 1
00956 keys 2
00957 keys 3
00958 keys 4
00959 control lamp zentralverriegelung safe -K133
00960 code switches zentralverriegelung driver's side
00961 code switches zentralverriegelung front seat passenger side
00962 alarm by inclination sensor
00963 signal line to the inclination sensor
00964 signal driver's door openly; Plus
00965 safety device for alarm horn -S158
00966 safety device for turn signals -S151
00967 turn signals left
00968 turn signals right
00969 safety device for heatable back window -S41
00971 relays for heatable windshield -J410
00972 relays for heatable windshield on the right of -J411
00973 switches for heatable back window -E15
00974 switches for heatable windshield -E180
00975 heatable back window -Z1
00976 control lamp for heatable windshield -K122
00977 headlight low beam left + right
00978 lamp for headlight low beam headlights on the left of -M29
00979 lamp for headlight low beam headlights on the right of -M31
00980 safety device for headlight low beam on the left of -S152
00981 safety device for headlight low beam on the right of -S153
00982 safety device for parking light on the left of -S154
00983 safety device for parking light on the right of -S155
00984 lamp for tail light on the left of -M4
00985 lamp for tail light on the right of -M2
00986 safety device for brake lights -S156
00987 lamp for stop light on the left of -M9
00988 lamp for stop light on the right of -M10
00989 safety device for consumer disconnection -S157
00990 consumer disconnection
00991 interior lighting
00992 consumer disconnection actively
00993 consumer disconnection inactively
00994 givers front vertical adjustment driver's seat -G215
00995 givers rear vertical adjustment driver's seat -G216
00996 givers vertical adjustment head restraint driver's seat -G217
00997 engine for adjustment driver's seat -V28
00998 engine for backrest adjustment driver's seat -V45
00999 engine for front vertical adjustment driver's seat -V29
01000 engine for rear vertical adjustment driver's seat -V30
01001 engine for head restraint adjustment driver's seat -V103
01002 tracers front vertical adjustment up, driver's seat -E208
01003 tracers front vertical adjustment off, driver's seat -E209
01004 tracers rear vertical adjustment up, driver's seat -E210
01005 tracers rear vertical adjustment off, driver's seat -E211
01006 tracers adjustment forwards, driver's seat -E212
01007 tracers adjustment back, driver's seat -E213
01008 reference: Emergency stop switch operates! (MEM off switch released -E190)
01009 givers adjustment, driver's seat -G218
01010 givers backrest adjustment, driver's seat -G219
01011 tracers head restraint adjustment up, driver's seat -E214
01012 tracers head restraint adjustment off, driver's seat -E215
01013 climatic compressor load signal
01014 output stage for exhaust thermostat
01015 radiator exhaust price increase
01016 luftablassventil throttle control absorption -N106
01017 compressor for throttle control absorption -V65
01018 exhausts for cooling agent -V7
01019 relays
01020 water pump -V36
01021 control lamp for differential lock -K81
01022 interior light, combination picture activates
01023 buzzers/gong -H3
01024 rain sensor -G213
01025 control error lamp defectively
01026 blowers for evaporators in the back -V20
01027 warm air blowers in the back -V47
01028 relays for blower -J323
01029 relays for air conditioning system -J32
01030 allotting pro rata aster zentralverriegelung driver's side, lock
01031 allotting pro rata aster zentralverriegelung driver's side, unlock
01032 allotting pro rata aster zentralverriegelung front seat passenger side, lock
01033 allotting pro rata aster zentralverriegelung front seat passenger side, unlock
01034 window lifters thermal protection actively, drivers
01035 window lifters thermal protection actively, front seat passengers
01036 window lifters thermal protection actively, HL
01037 window lifters thermal protection actively, HR
01038 zentralverriegelung thermal protection
01039 givers for coolant temperature gauge -G2
01040 ABS/transmission electrical connection 2
01041 ASR function implausibly
01042 controller does not code
01043 controller: wrong software-Version
01044 controller wrongly codes
01045 switches for Tiptronic -F189
01046 control lamp for brake lining -K32
01047 control lamp for Zweikreis-und parking brake plant -K7
01048 control lamp for Diesel electronics -K104
01049 on-board tension Kl. 50
01050 glow plug monitoring
01051 actuator amount of fuel regulation -V117
01052 potentiometers for load signal -G157
01053 valve for beginning of injecting -N182
01054 relays for supply voltage clamp 30 -J317
01055 givers for Kraftstoffoerderbeginn -G158
01056 function: Equalizing charge
01057 function: Tension constant charge
01058 function: Current constant charge
01059 givers for rotor situation of -G159
01060 givers for coil temperature groove reason of -G160
01061 givers for coil temperature end winding -G161
01062 signal for battery power reduction
01063 switches for e-recognition selector lever -F271
01064 clamp 58d - Dimmung interior light
01065 connection RNS to the TV Antennenverstaerker
01066 geschwindigkeitssignal of instrument panel
01067 valve for disconnection 2. Heat exchanger -N317
01068 relays for hydraulic pump clutch plate -J498
01069 pressure system brake booster
01070 relays for starter -J53
01071 givers for clutch way -G162
01072 negative pressure vent for clutch plate -N183
01073 pressure system clutch
01074 ventilation valve for clutch plate -N184
01075 relays for unterdruckpumpe -J318
01076 relays for hydraulic pump clutch -J319
01077 negative pressure switches brake booster -F190
01078 switches for course manipulation -F191
01079 relays for guidance hydraulics -J320
01080 switches power steering systems support -F192
01081 priority switching valve -N185
01082 control lamp for fuel reserve -K105
01083 control lamp for lack of washing water -K106
01084 control lamp for temperature warning 0°C -K107
01085 control lamp for temperature warning 4°C -K108
01086 givers for speedometer -G22
01087 basic adjustment not accomplished
01088 mixture adjustment 2
01089 switches for clamps put down -F204
01090 switches for clamps raised -F203
01091 switches for verdeck in front -F202
01092 switches for verdeck put down -F171
01093 switches for box covercover box covers above -F201
01094 switches 3 box covercover box cover on the left of -F195
01095 switches of 2 box covercover box covers on the left of -F197
01096 switches 1 box covercover box cover on the left of -F199
-F172 locks 01097 switches for verdeck
01098 switches for rear flap to -F206
01099 switches for trunk locks
01100 switches for trunk unlocks
01101 switches for unblocking barrier -F205
01102 switches 3 box covercover box cover on the right of -F196
01103 switches of 2 box covercover box covers on the right of -F198
01104 switches 1 box covercover box cover on the right of -F200
01105 single solenoid valve 8 -N186
01106 relays for window lifters lower -J291
01107 control light for verdeck -K98
01108 relays for window lifters raise -J292
01109 relays for hydraulic pump -J321
01110 magnet for unblocking barrier -N187
01111 actuator 1 for trunk lock
01112 current supply for actuator 1 and 2
01113 actuator 2 for trunk lock
01114 switches for parking brake control of -F9
01116 actuator for unblockingunblocking unblocking
01117 load signal for generator clamp DF
01118 engine preliminary heating
01119 signal for course recognition
01120 cam shaft adjustment 1
01121 cam shaft adjustment 2
01122 resounding givers 2 -G163
01123 control incorrectly
01124 load time monitoring
01125 suction tube change-over
01126 signal for engine speed
01127 control lamp for fuel reserve -K16
01128 read coil for going away safety device -D2
01129 s-contact -H15
01130 starting from self-service impulse
01131 control turn signals
01132 infrared sensor in front -G166
01133 infrared sensor in the back -G167
01134 alarm horn -H12
01135 sensors for interior monitoring
01136 starters starting interruption
01137 switches for zentralverriegelung; Verriegelungs-Kontakte
01138 switches for zentralverriegelung; Driver's door unblocking
01139 switches for zentralverriegelung; Passenger door unblocking
01140 switches for zentralverriegelung; Rear flap unblocking
01141 switches for rear flap unblocking -E165
01142 engines for zentralverriegelung; Driver's door and tank bolting device too
01143 engines for zentralverriegelung; Driver's door and tank bolting device up
01144 engine for zentralverriegelung; Passenger door open
01145 engine for zentralverriegelung; rear doors open
01146 engine for zentralverriegelung; Passenger door and rear doors too
01147 engine for rear flap bolting device -V120
01148 activation of the Safesicherung doors
01149 deactivation of the Safesicherung doors
01150 analog displays
01151 check switches for diesel engine -F207
01152 switches for course monitoring -F209
01153 switches for Ecomatic -E163
01154 push button switches for coupling system -F210
01155 clutch
01156 switches for course recognition -F208
01157 supply voltage for alarm horn
01158 supply voltage for turn signals
01159 lines for Safesicherung
01160 relays for glow plug cooling agent -J325
01161 output stage cam shaft control valve
01162 burn misfires
01163 ignition copy
01164 ESP enterprise
01165 butterfly valve control unit -J338
01166 signal for engine moment
01167 valve for vollastanschlag -N194
01168 valve for idling speed rise -N177
01169 tuerkontaktschalter driver's side -F2
01170 givers for injecting duration -G175
01171 temperature sensors passenger seat -G60
01172 temperature sensors driver's seat -G59
01173 engine for adjustment driver's seat -V28
01174 engine for vertical adjustment driver's seat -V138
01175 adjusters for heatable driver's seat -E94
01176 keys
01177 engine expensive equipment not entitled
01178 data bus drive, bus peace
01179 key programming wrongly
01180 engine/climatic compressor disconnection - electrical connection
01181 initialization: only 2 keys learned
01182 elevator adaptation
01183 CAT flare
01184 givers for leaking out temperature in the back -G174
01185 fresh air blowers in the back -V80
01186 actuator for air distribution in the back -V136
01187 actuator for temperature flap in the back -V137
01188 controller/magnetic clutch - electrical connection
01189 actuator for air distribution in front -V145
01190 controller/actuators - electrical connection
01191 engines for seat adjustment
01192 clutch for transducer bypass
01193 relays for small amount of heat -J359
01194 relays for large amount of heat -J360
01196 engine/transmission CAN bus
01197 data bus drive wrong software conditions
01198 data bus comfort wrong software conditions
01199 engine/ABS - electrical connection
01200 supply voltage of ABS valves
01201 supply voltage ABS pump
01202 diagnostic line short-circuit
01203 ABS/instrument panel employment - electrical connection
01204 givers for engine temperature -G27
01205 relays for Climatronic -J254
01206 signal for time interval ignition out
01207 controller for additional heating system -J364
01208 data record changes
01209 number of revolutions signal generator clamp W
switching position learns 01210 controller
01211 fuzes for belt-taut in the back driver's side -N196
01212 fuzes for belt-taut in the back front seat passenger side -N197
01213 fuzes for belt-taut in the back center -N198
01214 Crashdaten of belt-taut stored
01215 seat allocation sensor in the back driver's side -G177
01216 seat allocation sensor in the back front seat passenger side -G178
01217 fuzes for Seitenairbag in front driver's side -N199
01218 fuzes for Seitenairbag in front front seat passenger side -N200
01219 fuzes for Seitenairbag in the back driver's side -N201
01220 fuzes for Seitenairbag in the back front seat passenger side -N202
01221 Crashsensor Seitenairbag driver's side -G179
01222 Crashsensor Seitenairbag front seat passenger side -G180
01223 signal zentralverriegelung open
01224 equipment wrongly adjusted
01225 funkempfaenger standheizung -R64
01226 Crashdaten Seitenairbag driver's side stored
01227 Crashdaten Seitenairbag front seat passenger side stored
01228 code switches disconnection Airbag, front seat passenger side -E224
01229 sensor for air humidity, air conditioning system -G260
01230 givers for leaking out temperature floor space on the left of g 261
01231 givers for leaking out temperature floor space on the right of g 262
01232 regulating valve for compressor of the air conditioning system -N280
01233 stop valve for cooling agent, heating -N279
01234 controller for heatable windshield -J505
01235 secondary air injecting valve -N112
01236 magnet for selector lever barrier -N110
01237 fuel turn off valve -N109
01238 firing angle adjustment
01239 ventilation valve butterfly valve plate -N97
01240 bleed valve butterfly valve plate -N117
01241 single solenoid valve 2 for activated charcoal containers -N115
01242 output stages in the controller
01243 valve for register August tubing change-over -N156
01244 controller Lambdasondenheizung -J209
01245 pressure plates -N73
01246 relays for syphon preliminary heating -J81
01247 single solenoid valve 1 for activated charcoal containers -N80
01248 Zweiwegeventil-Vollastanreicherung-N54
01249 einspritzventil cylinder 1 -N30
01250 einspritzventil cylinder 2 -N31
01251 einspritzventil cylinder 3 -N32
01252 einspritzventil cylinder 4 -N33
01253 einspritzventil cylinder 5 -N83
01254 einspritzventil cylinder 6 -N84
01255 einspritzventil cylinder 7 -N85
01256 einspritzventil cylinder 8 -N86
01257 valve for no-load operation stabilization -N71
01258 choke plates -V63
01259 fuel pump relays -J17
01260 valve for schubabschaltung -N65
01261 clock valve for Lambdaregelung -N7
01262 single solenoid valve for load pressure control -N75
01263 cold weather starting valve -N17
01264 relays for secondary tire pump -J299
01265 valve for recycling of exhaust gases -N18
01266 relays for glow plugs -J52
01267 controller for glow automatic timer -J179
01268 mixing plates -N146
01269 valve for beginning of injecting -N108
01270 magnetic clutch for air conditioning system -N25
01271 actuator for temperature flap -V68
01272 actuator for central flap -V70
01273 fresh air blowers -V2
01274 actuator for stagnation pressure flap -V71
01275 code switches disconnection Seitenairbags in the back -E280
01276 hydraulic pump for ABS -V64
01277 relays for hydraulic pump ABS -J185
01278 switching off relays for EDS -J263
01279 givers for longitudinal acceleration -G251
01280 Airbag front seat passenger side is switched off
01281 Airbag driver's side is switched off
01282 transfer valve for suction tube flap -N239
01283 engine for suction tube flap -V157
01284 Seitenairbag driver's side is switched off
01285 Seitenairbag front seat passenger side is switched off
01286 of belt-taut driver's side is switched off
01287 of belt-taut front seat passenger side is switched off
01288 supply voltage Kl. 30
01289 supply voltage Kl. 15
01290 reference tension guidance assistance
01291 code switches disconnection Seitenairbag in the back, driver's side -E295
01292 code switches disconnection Seitenairbag in the back, front seat passenger side -E296
01293 control lamp for Seitenairbag out, in the back driver's side -K167
01294 control lamp for Seitenairbag out, in the back front seat passenger side -K168
01295 controller in the instrument panel employment wrongly codes
01296 givers for leaking out temperature center -G191
01297 givers for leaking out temperature floor space -G192
01299 diagnostic interfaces for data bus
01300 controller for navigation with CD drive assembly -J401
01301 controller for phonetic input -J507
01302 controller for telematics
01303 sending and receiver for telephone
01304 radio
01305 data bus display
01306 fast data bus display
01307 fiber-optic cable data bus display
01308 controller for roof electronics -J528
01309 controller for guidance assistance defectively
01310 controller for level regulation -J197
01311 data bus information
01312 data bus drive defectively
01313 data bus drive in the fail-safe
01314 engine expensive equipment
01315 transmission expensive equipment
01316 braking expensive equipment
01317 controller in the combination instrument
01318 controller for injection pump
01319 controller for longitudinal control -J428
01320 controller for Climatronic -J255
01321 controller for Airbag -J234
01322 controller for multi-functional unit -J501
01323 controller for automatic clutch -J439
01324 controller for all-wheel drive -J492
01325 controller for tire pressure monitoring
01326 controller for multi-function steering wheel -J453
01327 controller for a park assistance
01328 data bus comfort
01329 data bus comfort in the fail-safe
01330 central controller for comfort system -J393
01331 door expensive equipment driver's side -J386
01332 door expensive equipment front seat passenger side -J387
01333 door expensive equipment HL -J388
01334 door expensive equipment HR -J389
01335 controller for seat/mirror position driver
01336 company data bus comfort
01337 door interior grasp lighting
01338 signal doors not closed
01339 door warning lamp
01340 mirror adjustment switches
01341 controller in the instrument panel employment at the comfort CAN -J285
01342 engine expensive equipment 2 (Slave 1)
01343 engine expensive equipment 3 (Slave 2)
01344 gas-discharge lamp
01345 central module for gas-discharge lamp
01346 line to the ignition module
01347 line to the gas-discharge lamp
01348 control lamp for interior monitoring disconnection -K162
01349 alarm by sensor for theft alarm system in front
01350 alarm by sensor for theft alarm system in the back
01351 line for communication on mass
01352 line for clock pulse in front, 5V level
01353 line for clock pulse in the back, 5V level
01354 enabling signal going away barrier
01355 signal; All windows open
01356 signal; All windows and sliding issuing roof close
01357 engine for gas cap bolting device -V155
01358 switches for support rod driver's side -E150
01359 switches for support rod front seat passenger side -E198
01360 switches for theft alarm system open
01361 switches for theft alarm system close
01362 switches for rear flap close -F124
01363 switches for zentralverriegelung, driver's door -F59
01364 switches for zentralverriegelung, passenger door -F114
01365 LOCK/UNLOCK switch/bolting device tracer inside
01366 opening by Crash signal
01367 disconnection of the pump for zentralverriegelung
01368 alarm by switch trunk
01369 alarm by switch hood
01370 alarm by interior monitoring
01371 alarm by tuerkontaktschalter driver's side
01372 alarm by tuerkontaktschalter in the back/front seat passenger side
01373 alarm by earth bar radio
01374 alarm by clamp 15
01375 valves for engine storage stage 1
01376 number of revolutions signal for injection pump
01377 ultrasonic sensor left for theft alarm system -G170
01378 ultrasonic sensor right for theft alarm system -G171
01379 switches for interior monitoring -E183
01380 alarm by sensor for theft alarm system at the rear left
01381 alarm by sensor for theft alarm system in the back right
01382 alarm by sensor for theft alarm system in front left
01383 alarm by sensor for theft alarm system in front right
01384 alarm by glass break sensor
01385 control lamp for alarm installation -K95
01387 line for voltage supply
01388 line for clock pulse
01389 switches for rear flap open -F124
01393 givers for level regulation -G84
01394 control lamp for level regulation -K134
01395 engine for compressor level regulation -V66
01396 valves for rear suspension struts -N150/-N151
01397 solenoid drip valve level regulation -N111
01398 signal line of zentralverriegelung: Doors up
01399 relays for compressor level regulation -J403
01400 level regulation
01402 data line of navigation
01403 glass break sensors in the back
01404 valves for engine storage stage 2
01405 valve 2 for recycling of exhaust gases -N213
01406 no flaming formation
01407 flaming abort
01408 disconnection by undervoltage (fixed value)
01409 repeated flaming abort
01410 heater overheats
01411 temperature sensors -G18
01412 glow plug with Flammwaechter-Q8
01413 dosing pump -V54
01414 combustion air blowers -V6
01415 circulation pump -V55
01416 signal for control fresh air blower
01422 hydraulic pump for FDR -V156
01423 sensor for transverse acceleration -G200
01424 givers for turning rate -G202, signal line
01425 givers for turning rate -G202, reference line
01426 control unit in the steering wheel -E221
01434 relays for stop light suppression ESP -J508
01435 givers 1 for brake pressure -G201
01437 rule situation not learned
01440 fuel level signal
01441 givers for lack of fuel -G210
01442 misfires by lack of fuel
01443 adjustment at battery does not take place
01444 disconnection by undervoltage (AUTOMATIC)
01445 givers for adjustment, driver's seat -G227
01446 givers for backrest adjustment, driver's seat -G230
01447 givers for vertical adjustment, driver's seat -G231
01448 givers for neigungsverstellung, driver's seat -G232
01449 switches for neigungsverstellung driver's seat -E222, back
01450 switches for neigungsverstellung driver's seat -E222, forwards
01451 switches for along and vertical adjustment -E61, up
01452 switches for along and vertical adjustment -E61, off
01453 switches for along and vertical adjustment -E61, forwards
01454 switches for along and vertical adjustment -E61, back
01455 switches for backrest adjustment -E96, forwards
01456 switches for backrest adjustment -E96, back
01457 signal at mirror/steering column controller
01458 signal of zentralverriegelung
01459 tracers drivers 1/MEMORY seat -E218
01460 tracers drivers 2/MEMORY seat -E219
01461 tracers drivers 3/MEMORY seat -E220
01464 givers for brake pressure/transverse acceleration
01482 engines for zentralverriegelung
01483 control tail cover remote unblocking
01484 allotting pro rata aster zentralverriegelung lock
01485 allotting pro rata aster zentralverriegelung unlock
01486 system function test activates
01488 givers for coolant temperature, heating -G241
01489 overheat thermoresistors -G189
01490 automatic flame guards -G64
01491 glow plug for heating -Q9
01492 function barrier
01522 control listeners for telephone -R37
01523 microphone for telephone -R38
01526 tracers for emergency call -E276
01527 tracers for breakdown call -E275
01528 auxiliary antenna for telematics -R90
01529 auxiliary loudspeakers for telematics -R91
01531 stand-by battery
01532 signal line to the combination instrument
01533 searchlight beam Kl.56
01534 control actuator for shining width regulation on the left of -V48
01535 control actuator for shining width regulation on the right of -V49
01537 givers for vehicle level - supply voltage
01539 headlights were not adjusted
01542 givers for turning rate -G202
01543 buzzers for a park assistance -H15
01544 function announcement
01545 givers for a park assistance, at the rear left -G203
01546 givers for a park assistance, at the rear left, center -G204
01547 givers for a park assistance, in the back right, center -G205
01548 givers for a park assistance, in the back on the right of -G206
01549 supply voltage for giver a park assistance
01550 signal for reverse gear
01557 contact switches in the lockcylinder driver's side -F241 open
01558 contact switches in the lockcylinder driver's side -F241 close
01559 driver's door lock
01560 passenger door lock
01561 door lock HL
01562 door lock HR
01563 switches for support rod driver's side -E150, LOCK
01564 switches for Innenverr. Driver's side -E150, UNLOCK
01565 luggage compartment light -W3
01566 signal for interior monitoring activate
01568 signal comfort opening
01569 signal comfort locking
01570 turn-off delay Kl. 15
01571 signal for seat MEMORY
01572 alarm by tuerkontaktschalter front seat passenger side side
01573 alarm by tuerkontaktschalter HL
01574 alarm by tuerkontaktschalter HR
01575 regulation switched off
01577 disconnection by temperature rise
01578 indicator light for Airbag out, front seat passenger side -K145
01581 wrong construction unit recognized
01582 signal for coolant temperature
01585 contact switches in the lockcylinder front seat passenger side -F242, open
01586 contact switches in the lockcylinder front seat passenger side -F242, close
01588 fuzes for Kopfairbag driver's side -N251
01589 fuzes for Kopfairbag front seat passenger side -N252
01592 sensor for air quality -G238
01593 heatable windshield -Z2
01594 controller wrong chassis number
01596 actuator for fresh air/circulating air flap -V154
01613 relays for pump fuel cooling
01625 buzzers for a park assistance in front -H22
01626 givers for a park assistance, in front on the right of -G252
01627 givers for a park assistance, in front right, center -G253
01628 givers for a park assistance, in front left, center -G254
01629 givers for a park assistance, in front on the left of -G255
01638 Crashsensor Seitenairbag driver's side in the back -G256
01639 Crashsensor Seitenairbag front seat passenger side in the back -G257
01646 Kopfairbag driver's side is switched off
01647 Kopfairbag front seat passenger side is switched off
01656 Crashsignal
01686 controller for radiator exhaust oh run -J138
01695 givers 2 for fuel temperature -G248
01719 givers for adjustment, passenger seat -G278
01720 givers for backrest adjustment, passenger seat -G279
01721 givers for rear vertical adjustment, passenger seat -G280
01722 givers for front vertical adjustment, passenger seat -G281
01724 switches for adjustment, passenger seat -E64, forwards
01725 switches for adjustment, passenger seat -E64, back
01726 switches for backrest adjustment, Beifahrersitz-E98, forwards
01727 switches for backrest adjustment, passenger seat -E98, back
01728 switches for rear vertical adjustment, passenger seat -E66, up
01729 switches for rear vertical adjustment, passenger seat E66, off
01730 switches for front vertical adjustment, passenger seat -E65, up
01731 switches for front vertical adjustment, passenger seat -E65, off
01748 switches for Tiptronic in the steering wheel, highly
01749 switches for Tiptronic in the steering wheel, down
01767 givers for vehicle level left
01768 givers for vehicle level right
01769 givers for vehicle level VR -G289
01770 givers for compressor temperature -G290
01771 controller for shining width regulation
01772 signal line of pressure transducer -G291
01773 valve for accumulator -N311
01774 controller for shining width regulation, supply -J431
01775 signal line to the controller for shining width regulation -J431
01776 control unit for level regulation -E281 defectively
01777 redundant signalpfad of control unit for level regulation -E281
01780 givers for vehicle level
01781 extreme vehicle inclined conditions
01796 telematics SIM map
01809 actuator for temperature flap on the left of -V158
01810 actuator for temperature flap on the right of -V159
01836 compressor switched off
01841 potentiometers -G220 in the actuator -V158 (for temperature flap left)
01842 potentiometers -G221 in the actuator -V159 (for temperature flap right)
16397 bank 1, cam shaft adjustment discharge opening malfunctioning
16407 bank 2, cam shaft adjustment discharge opening malfunctioning
16485 air mass measurers -G70 implausible signal
16486 air mass measurers signal too small
16487 air mass measurers signal too largely
16490 suction tube pressure/air pressure -G71/-F96 implausible signal
16491 suction tube pressure/air pressure -G71/-F96 signal too small
16496 intake air temperature signal too small
16497 intake air temperature signal too largely
16500 givers for coolant temperature -G62 implausible signal
16501 givers for coolant temperature -G62 signal too small
16502 givers for coolant temperature -G62 signal too largely
16504 givers for coolant temperature -G62 of electrical errors in the electric circuit
16505 butterfly valve potentiometers implausible signal
16506 butterfly valve potentiometers signal too small
16507 butterfly valve potentiometers signal too largely
16514 bank 1, probe 1 electrical error in the electric circuit (malfunctioning)
16515 bank 1, probe 1 tension too small
16516 bank 1, probe 1 tension too largely
16517 bank 1, probe 1 signal too slowly
16518 bank 1, probe 1 no activity
16519 bank 1, probe 1 heizstromkreis electrical error in the electric circuit
16520 bank 1, probe 2 electrical error in the electric circuit
16521 bank 1, probe 2 tension too small
16522 bank 1, probe 2 tension too largely
16523 bank 1, probe 2 signal too slowly
16524 bank 1, probe 2 no activity
16525 bank 1, probe 2 heizstromkreis electrical error in the electric circuit
16534 bank 2, probe 1 electrical error in the electric circuit (malfunctioning)
16535 bank 2, probe 1 tension too small
16536 bank 2, probe 1 tension too largely
16537 bank 2, probe 1 signal too slowly
16538 bank 2, probe 1 no activity
16540 bank 2, probe 2 electrical error in the electric circuit
16541 bank 2, probe 2 tension too small
16542 bank 2, probe 2 tension too largely
16543 bank 2, probe 2 signal too slowly
16544 bank 2, probe 2 no activity
16554 bank 1, fuel calculation system malfunctioning
16555 bank 1, fuel calculation system system too lean
16556 bank 1, fuel calculation system system too fat
16557 bank 2, fuel calculation system malfunctioning
16558 bank 2, fuel calculation system system too lean
16559 bank 2, fuel calculation system system too fat
16576 givers for fuel pressure -G247 short-circuit after mass
16581 givers for oil temperature -G8 signal too small
16582 givers for oil temperature -G8 signal too largely
16585 einspritzventil Zyl. 1 -N30 of electrical errors in the electric circuit
16586 einspritzventil Zyl. 2 -N31 of electrical errors in the electric circuit
16587 einspritzventil Zyl. 3 -N32 of electrical errors in the electric circuit
16588 einspritzventil Zyl. 4 -N33 of electrical errors in the electric circuit
16593 einspritzventil Zyl. 9 -N299 of electrical errors in the electric circuit
16594 einspritzventil Zyl. 10 -N300 of electrical errors in the electric circuit
16595 einspritzventil Zyl. 11 -N301 of electrical errors in the electric circuit
16596 einspritzventil Zyl. 12 -N302 of electrical errors in the electric circuit
16603 maximum engine speed exceeded
16606 angle sensors 2 for butterfly valve drive -G188 signal too small
16607 angle sensors 2 for butterfly valve drive -G188 signal too largely
16611 givers for position of the gas pedal -G79 signal too small
16612 givers for position of the gas pedal -G79 signal too largely
16620 givers for load pressure -G31 implausible signal
16621 givers for load pressure -G31 signal too small
16622 givers for load pressure -G31 signal too largely
16646 einspritzventil Zyl. 1 -N30 short-circuit after pluses
16649 einspritzventil Zyl. 2 -N31 short-circuit after pluses
16652 einspritzventil Zyl. 3 -N32 short-circuit after pluses
16655 einspritzventil Zyl. 4 -N33 short-circuit after pluses
16669 einspritzventil Zyl. 9 -N299 short-circuit after mass
16670 einspritzventil Zyl. 9 -N299 short-circuit after pluses
16672 einspritzventil Zyl. 10 -N300 short-circuit after mass
16673 einspritzventil Zyl. 10 -N300 short-circuit after pluses
16675 einspritzventil Zyl. 11 -N301 short-circuit after mass
16676 einspritzventil Zyl. 11 -N301 short-circuit after pluses
16678 einspritzventil Zyl. 12 -N302 short-circuit after mass
16679 einspritzventil Zyl. 12 -N302 short-circuit after pluses
16684 burn misfires recognized
16685 Zyl. 1 burn misfire recognized
16686 Zyl. 2 burn misfires recognized
16687 Zyl. 3 burn misfire recognized
16688 Zyl. 4 burn misfires recognized
16689 Zyl. 5 burn misfires recognized
16690 Zyl. 6 burn misfires recognized
16691 Zyl. 7 burn misfires recognized
16692 Zyl. 8 burn misfires recognized
16693 Zyl. 9 burn misfires recognized
16694 Zyl. 10 burn misfires recognized
16695 Zyl. 11 burn misfire recognized
16696 Zyl. 12 burn misfires recognized
16705 givers for engine speed -G28 implausible signal
16706 givers for engine speed -G28 no signal
16708 knocking regulation malfunctioning
16709 knocking sensor 1 -G61 of electrical errors in the electric circuit
16710 knocking sensor 1 -G61 implausible signal
16711 knocking sensor 1 -G61 signal too small
16712 knocking sensor 1 -G61 signal too largely
16716 knocking sensor 2 -G66 signal too small
16717 knocking sensor 2 -G66 signal too largely
16719 givers for engine speed -G28 malfunctioning
16721 crankshaft position sensor signal too small
16724 cam shaft position sensor -G40 malfunctioning
16725 cam shaft position sensor -G40 implausible signal
16726 cam shaft position sensor -G40 signal too small
16727 cam shaft position sensor -G40 signal too largely
16730 cam shaft position sensor -G163 implausible signal
16735 ignition control Zyl. 1 malfunctioning
16736 ignition control Zyl. 2 malfunctioning
16750 cam shaft position sensor -G300 implausible signal
16764 glow plug -Q6 of electrical errors in the electric circuit
16775 cam shaft position sensor -G301 implausible signal
16785 recycling of exhaust gases system throughput too small
16786 recycling of exhaust gases system throughput too largely
16787 valve for recycling of exhaust gases -N18 malfunctioning
16788 recycling of exhaust gases system rule difference
16791 potentiometers for recycling of exhaust gases -N212 signal too small
16792 potentiometers for recycling of exhaust gases -N212 signal too largely
16795 secondary air system flow incorrectly
16804 bank 1, catalyst system effect too small
16805 Vorkatalysator bank 1, effect too small
16806 bank 1, main catalyst effect too small
16814 bank 2, catalyst system effect too small
16815 Vorkatalysator bank 2, effect too small
16816 bank 2, main catalyst effect too small
16825 tank ventilation system throughput incorrectly
16827 tank ventilation system of electrical errors in the electric circuit
16845 Kraftstoffuellstandssignal implausible signal
16885 vehicle speed signal implausible signal
16887 vehicle speed signal signal too largely
16890 idling regulation number of revolutions under desired value
16891 idling regulation number of revolutions over desired value
16894 throttle idle microswitches -F60 malfunctioning
16896 idling speed influence not possible
16916 pressure sensor for air conditioning system signal too small
16917 pressure sensor for air conditioning system signal too largely
16944 voltage supply implausible signal
16946 voltage supply tension too small
16947 voltage supply tension too largely
16952 switches for GRA -E45 implausible signal
16955 stop light switches f implausible signal
16985 controller defectively
16987 controller defectively
16988 controller defectively
16989 controller defectively
16990 controller defectively
16991 butterfly valve control unit -J338 undervoltage during basic adjustment
17022 butterfly valve control unit -J338 implausible signal
17069 main relays -J271 interruption
17070 main relays -J271 short-circuit after mass
17071 main relays -J271 short-circuit after pluses
17086 controller defectively
17087 stop light switches f of electrical errors in the electric circuit
17090 drive position sensor -F125 implausible signal
17094 givers for transmission oil temperature -G93 of electrical errors in the electric circuit
17095 givers for transmission oil temperature -G93 implausible signal
17096 givers for transmission oil temperature -G93 signal too small
17097 givers for transmission oil temperature -G93 signal too largely
17100 givers for transmission entrance number of revolutions -G182 implausible signal
17101 givers for transmission entrance number of revolutions -G182 no signal
17105 givers for transmission output speed -G195 implausible signal
17106 givers for transmission output speed -G195 no signal
17110 number of revolutions signal of the engine expensive equipment implausible signal
17111 number of revolutions signal of the engine expensive equipment no signal
17114 course/translation monitoring wrong speed ratio
17115 1. Course wrong speed ratio
17116 2. Course wrong speed ratio
17117 3. Course wrong speed ratio
17118 4. Course wrong speed ratio
17119 5. Course wrong speed ratio
17125 clutch for transducer bypass no power transmission
17134 switching valve 1 single solenoid valve 1 -N88 malfunction
17135 switching valve 1 single solenoid valve 1 -N88 interruption/short-circuit after mass
17136 switching valve 1 single solenoid valve 1 -N88 short-circuit after pluses
17137 switching valve 1 single solenoid valve 1 -N88 of electrical errors in the electric circuit
17140 switching valve 2 single solenoid valve 2 -N89 interruption/short-circuit after mass
17141 switching valve 2 single solenoid valve 2 -N89 short-circuit after pluses
17142 switching valve 2 single solenoid valve 2 -N89 of electrical errors in the electric circuit
17145 switching valve 3 single solenoid valve 3 -N90 interruption/short-circuit after mass
17146 switching valve 3 single solenoid valve 3 -N90 short-circuit after pluses
17147 switching valve 3 single solenoid valve 3 -N90 of electrical errors in the electric circuit
17418 einspritzventil Zyl.9 -N299 interruption
17419 einspritzventil Zyl. 10 -N300 interruption
17420 einspritzventil Zyl. 11 -N301 interruption
17421 einspritzventil Zyl. 12 -N302 interruption
17428 fuel pressure control rule border exceeded
17433 regulating valve for fuel pressure -N276 of mechanical errors
17463 bank 1, cam shaft adjustment discharge opening short-circuit after pluses
17464 bank 1, cam shaft adjustment discharge opening short-circuit after mass
17465 bank 1, cam shaft adjustment discharge opening interruption
17466 bank 2, cam shaft adjustment discharge opening short-circuit after pluses
17467 bank 2, cam shaft adjustment discharge opening short-circuit after mass
17468 bank 2, cam shaft adjustment discharge opening interruption
17471 fuel pressure control rule border fell below
17472 fuel pressure system of mechanical errors
17473 fuel pressure control rule difference
17481 air mass measurers 2 -G246 signal too small
17482 air mass measurers 2 -G246 signal too largely
17483 Lambda regulation exhaust bank 3 system too lean
17484 Lambda regulation exhaust bank 3 system too fat
17485 Lambda regulation exhaust bank 4 system too lean
17486 Lambda regulation exhaust bank 4 system too fat
17487 Lambda regulation exhaust bank 3 implausible control value
17488 Lambda regulation exhaust bank 4 implausible control value
17489 exhaust bank 3, mixture adaptation range 1 lean border fell below
17490 exhaust bank 3, mixture adaptation range 2 lean border fell below
17491 exhaust bank 3, mixture adaptation range 1 fat border exceeded
17492 exhaust bank 3, mixture adaptation range 2 fat border exceeded
17493 exhaust bank 4, mixture adaptation range 1 lean border fell below
17494 exhaust bank 4, mixture adaptation range 2 lean border fell below
17495 exhaust bank 4, mixture adaptation range 1 fat border exceeded
17496 exhaust bank 4, mixture adaptation range 2 fat border exceeded
17497 bank 2, mixture adaptation range 1 lean border fell below
17499 bank 2, mixture adaptation range 1 fat border exceeded
17509 bank 1, probe 1 tension too small/leakage air
17510 bank 1, probe 1 heizstromkreis short-circuit after pluses
17511 bank 1, probe 1 heizstromkreis achievement too small
17513 bank 1, probe 2 heizstromkreis short-circuit after pluses
17514 bank 2, probe 1 tension too small/leakage air
17515 bank 2, probe 1 heizstromkreis short-circuit after pluses
17516 bank 2, probe 1 heizstromkreis achievement too small
17518 bank 2, probe 2 heizstromkreis short-circuit after pluses
17519 Lambda regulation (bank 1) system too lean
17520 Lambda regulation (bank 1) system too fat
17521 bank 1, probe 1 internal resistance too largely
17522 bank 1, probe 2 internal resistance too largely
17523 bank 1, probe 1 heizstromkreis short-circuit after mass
17524 bank 1, probe 1 heizstromkreis interruption
17525 bank 1, probe 2 heizstromkreis short-circuit after mass
17526 bank 1, probe 2 heizstromkreis interruption
17527 bank 2, probe 1 heizstromkreis short-circuit after mass
17528 bank 2, probe 1 heizstromkreis interruption
17529 bank 2, probe 2 heizstromkreis short-circuit after mass
17530 bank 2, probe 2 heizstromkreis interruption
17535 bank 1, mixture adaptation (mult.) System too fat
17536 bank 1, mixture adaptation (mult.) System too lean
17537 bank 2, mixture adaptation (mult.) System too fat
17538 bank 2, mixture adaptation (mult.) System too lean
17539 bank 2, probe 1 internal resistance too largely
17540 banks 1+2, probe 1 heizstromkreis short-circuit after pluses
17541 banks 1+2, probe 1 heizstromkreis of electrical errors
17544 bank 1, mixture adaptation (ADD.) System too lean
17545 bank 1, mixture adaptation (ADD.) System too fat
17546 bank 2, mixture adaptation (ADD.) System too lean
17547 bank 2, mixture adaptation (ADD.) System too fat
17548 bank 2, probe 2 internal resistance too largely
17549 vice version implausible value
17551 vice version border exceeded
17552 air mass measurers -G70 interruption/short-circuit after mass
17553 air mass measurers -G70 short-circuit after pluses
17554 air mass measurers -G70 supply voltage
17555 Lambda regulation bank 2 system too lean
17556 Lambda regulation bank 2 system too fat
17557 Lambda regulation bank 1 implausible control value
17558 Lambda regulation bank 2 implausible control value
17559 bank 1, mixture adaptation range 1 lean border fell below
17560 bank 1, mixture adaptation range 2 lean border fell below
17563 givers for suction tube pressure -G71 short-circuit after pluses
17564 givers for suction tube pressure -G71 interruption/short-circuit after mass
17565 givers for suction tube pressure -G71 supply voltage
17566 givers for suction tube pressure -G71 implausible signal
17567 signal air mass measurer 1/air mass measurer 2 implausible relationship
17568 givers for suction tube temperature -G72 short-circuit after mass
17569 givers for suction tube temperature -G72 interruption/short-circuit after pluses
17570 givers for fuel temperature -G81 short-circuit after mass
17571 givers for fuel temperature -G81 interruption/short-circuit after pluses
17572 givers for fuel temperature -G81 implausible signal
17573 bank 1, mixture adaptation range 1 fat border exceeded
17574 bank 1, mixture adaptation range 2 fat border exceeded
17575 air mass measurers 2 -G246 implausible signal
17576 air mass measurers 2 -G246 interruption/short-circuit after mass
17577 air mass measurers 2 -G246 short-circuit after pluses
17578 air mass measurers 2 -G246 supply voltage
17579 angle sensors 2 for butterfly valve drive -G188 implausible signal
17580 angle sensors 2 for butterfly valve drive -G188 signal too small
17581 angle sensors 2 for butterfly valve drive -G188 signal too largely
17582 bank 1, fuel calculation system deviation of the durations of injection
17584 bank 1, Lambdakorrektur behind Kat rule border reaches
17585 bank 2, Lambdakorrektur behind Kat rule border reaches
17586 linear Lambda probe pumping Rome interruption
17587 linear Lambdasonde/ pumping Rome short-circuit after mass
17588 linear Lambdasonde/ pumping Rome short-circuit after pluses
17589 linear Lambdasonde/ reference tension interruption
17590 linear Lambdasonde/ reference tension short-circuit after mass
17591 linear Lambdasonde/ reference tension short-circuit after pluses
17598 linear Lambdasonde/ reference tension implausibly
17600 givers for fuel pressure -G247 supply voltage
17601 givers for fuel pressure -G247 interruption/short-circuit after pluses
17602 regulating valve for fuel pressure -N276 short-circuit after pluses
17603 regulating valve for fuel pressure -N276 interruption/short-circuit after mass
17604 bank 1, probe 1 heizstromkreis of electrical errors
17605 bank 2, probe 1 heizstromkreis of electrical errors
17606 bank 1, probe 2 heizstromkreis of electrical errors
17607 bank 2, probe 2 heizstromkreis of electrical errors
17609 einspritzventil Zyl.1 -N30 electrical error in the electric circuit
17610 einspritzventil Zyl.2 -N31 electrical error in the electric circuit
17611 einspritzventil Zyl.3 -N32 electrical error in the electric circuit
17612 einspritzventil Zyl.4 -N33 electrical error in the electric circuit
17613 einspritzventil Zyl.5 -N83 electrical error in the electric circuit
17614 einspritzventil Zyl.6 -N84 electrical error in the electric circuit
17615 einspritzventil Zyl.7 -N85 electrical error in the electric circuit
17616 einspritzventil Zyl.8 -N86 electrical error in the electric circuit
17621 einspritzventil Zyl.1 -N30 short-circuit after pluses
17622 einspritzventil Zyl.2 -N31 short-circuit after pluses
17623 einspritzventil Zyl.3 -N32 short-circuit after pluses
17624 einspritzventil Zyl.4 -N33 short-circuit after pluses
17625 einspritzventil Zyl.5 -N83 short-circuit after pluses
17626 einspritzventil Zyl.6 -N84 short-circuit after pluses
17627 einspritzventil Zyl.7 -N85 short-circuit after pluses
17628 einspritzventil Zyl.8 -N86 short-circuit after pluses
17633 einspritzventil Zyl. 1 -N30 short-circuit after mass
17634 einspritzventil Zyl. 2 -N31 short-circuit after mass
17635 einspritzventil Zyl. 3 -N32 short-circuit after mass
17636 einspritzventil Zyl. 4 -N33 short-circuit after mass
17637 einspritzventil Zyl. 5 -N83 short-circuit after mass
17638 einspritzventil Zyl. 6 -N84 short-circuit after mass
17639 einspritzventil Zyl. 7 -N85 short-circuit after mass
17640 einspritzventil Zyl. 8 -N86 short-circuit after mass
17645 einspritzventil Zyl. 1 -N30 interruption
17646 einspritzventil Zyl. 2 -N31 interruption
17647 einspritzventil Zyl. 3 -N32 interruption
17648 einspritzventil Zyl. 4 -N33 interruption
17649 einspritzventil Zyl. 5 -N83 interruption
17650 einspritzventil Zyl. 6 -N84 interruption
17651 einspritzventil Zyl. 7 -N85 interruption
17652 einspritzventil Zyl. 8 -N86 interruption
17658 Kraftstoffuellstand too small
17663 givers for coolant temperature -G62 short-circuit after mass
17664 givers for coolant temperature -G62 interruption/short-circuit after pluses
17668 valve for pump/nozzle cylinder 1 -N240 implausible signal
17669 valve for pump/nozzle cylinder 1 -N240 rule border exceeded
17670 valve for pump/nozzle cylinder 1 -N240 rule border fell below
17671 valve for pump/nozzle cylinder 2 -N241 implausible signal
17672 valve for pump/nozzle cylinder 2 -N241 rule border exceeded
17673 valve for pump/nozzle cylinder 2 -N241 rule border fell below
17674 valve for pump/nozzle cylinder 3 -N242 implausible signal
17675 valve for pump/nozzle cylinder 3 -N242 rule border exceeded
17676 valve for pump/nozzle cylinder 3 -N242 rule border fell below
17677 valve for pump/nozzle cylinder 4 -N243 implausible signal
17678 valve for pump/nozzle cylinder 4 -N243 rule border exceeded
17679 valve for pump/nozzle cylinder 4 -N243 rule border fell below
17686 valve for fuel dosage -N290 short-circuit after pluses
17687 valve for fuel dosage -N290 interruption/short-circuit after mass
17688 air distributor for einspritzventile throughput too small
17691 air distributor for einspritzventile of electrical errors in the electric circuit
17694 air distributor for einspritzventile short-circuit after pluses
17695 circulating air valve for turbocharger -N249 interruption
17696 circulating air valve for turbocharger -N249 short-circuit after pluses
17697 circulating air valve for turbocharger -N249 short-circuit after mass
17700 thermostat for characteristic diagram-steered engine cooling -F265 interruption
17701 thermostat for characteristic diagram-steered engine cooling -F265 short-circuit after pluses
17702 thermostat for characteristic diagram-steered engine cooling -F265 short-circuit after mass
17704 errors in the cooling system
17707 valve for fuel dosage -N290 malfunctioning
17708 burn misfires recognized reason: Lack of fuel
17709 knocking regulation Zyl. 9 rule border reaches
17710 knocking regulation Zyl. 10 rule border reaches
17711 knocking regulation Zyl. 11 rule border reaches
17712 knocking regulation Zyl. 12 rule border reaches
17713 ignition control Zyl. 9 interruption
17714 ignition control Zyl. 9 short-circuit after pluses
17715 ignition control Zyl. 9 short-circuit after mass
17716 ignition control Zyl. 10 interruption
17717 ignition control Zyl. 10 short-circuit after pluses
17718 ignition control Zyl. 10 short-circuit after mass
17719 ignition control Zyl. 11 interruption
17720 ignition control Zyl. 11 short-circuit after pluses
17721 ignition control Zyl. 11 short-circuit after mass
17722 ignition control Zyl. 12 interruption
17723 ignition control Zyl. 12 short-circuit after pluses
17724 ignition control Zyl. 12 short-circuit after mass
17729 knocking sensor 3 -G198 signal too small
17730 knocking sensor 3 -G198 signal too largely
17731 knocking sensor 4 -G199 signal too small
17732 knocking sensor 4 -G199 signal too largely
17733 knocking regulation Zyl. 1 rule border reaches
17734 knocking regulation Zyl. 2 rule border reaches
17735 knocking regulation Zyl. 3 rule border reaches
17736 knocking regulation Zyl. 4 rule border reaches
17737 knocking regulation Zyl. 5 rule border reaches
17738 knocking regulation Zyl. 6 rule border reaches
17739 knocking regulation Zyl. 7 rule border reaches
17740 knocking regulation Zyl. 8 rule border reaches
17743 engine moment monitoring rule border exceeded
17744 engine moment monitoring rule border exceeded
17745 bank 1, cam shaft position sensor -G40 short-circuit after mass
17746 bank 1, cam shaft position sensor -G40 interruption/short-circuit after pluses
17747 crankshaft position/engine speed sensor exchanges
17748 cam shaft position/crankshaft position sensor wrong allocation
17749 ignition exit 1 short-circuit after mass
17750 ignition exit 1 short-circuit after pluses
17751 ignition exit 2 short-circuit after mass
17752 ignition exit 2 short-circuit after pluses
17753 ignition exit 3 short-circuit after mass
17755 bank 2, cam shaft position crankshaft position sensor wrong allocation
17756 ignition exit 1 interruption
17757 ignition exit 2 interruption
17763 ignition control Zyl. 1 interruption
17764 ignition control Zyl. 1 short-circuit after pluses
17765 ignition control Zyl. 1 short-circuit after mass
17766 ignition control Zyl. 2 interruption
17767 ignition control Zyl. 2 short-circuit after pluses
17768 ignition control Zyl. 2 short-circuit after mass
17769 ignition control Zyl. 3 interruption
17770 ignition control Zyl. 3 short-circuit after pluses
17771 ignition control Zyl. 3 short-circuit after mass
17772 ignition control Zyl. 4 interruption
17773 ignition control Zyl. 4 short-circuit after pluses
17774 ignition control Zyl. 4 short-circuit after mass
17775 ignition control Zyl. 5 interruption
17776 ignition control Zyl. 5 short-circuit after pluses
17777 ignition control Zyl. 5 short-circuit after mass
17778 ignition control Zyl. 6 interruption
17779 ignition control Zyl. 6 short-circuit after pluses
17780 ignition control Zyl. 6 short-circuit after mass
17781 ignition control Zyl. 7 interruption
17782 ignition control Zyl. 7 short-circuit after pluses
17783 ignition control Zyl. 7 short-circuit after mass
17784 ignition control Zyl. 8 interruption
17785 ignition control Zyl. 8 short-circuit after pluses
17786 ignition control Zyl. 8 short-circuit after mass
17793 controller defectively
17794 controller defectively
17795 controller defectively
17796 controller defectively
17797 controller 2 for Diesel direct fuel injection system -J494 defectively
17799 bank 2 cam shaft position sensor -G40 short-circuit after mass
17800 bank 2 cam shaft position sensor -G40 interruption/short-circuit after pluses
17801 ignition exit 1 electrical error in the electric circuit
17802 ignition exit of 2 electrical errors in the electric circuit
17803 ignition exit 3 electrical error in the electric circuit
17805 giver wheel for engine speed adaptation border reaches
17806 engine speed signal, TD short-circuit after mass
17807 engine speed signal, TD short-circuit after pluses
17808 valve for recycling of exhaust gases -N18 of electrical errors in the electric circuit
17809 valve for recycling of exhaust gases -N18 short-circuit after mass
17810 valve for recycling of exhaust gases -N18 short-circuit after pluses
17811 recycling of exhaust gases system rule difference
17812 recycling of exhaust gases system basic adjustment not accomplished
17815 temperature sensors for recycling of exhaust gases -G98 signal too small
17816 temperature sensors for recycling of exhaust gases -G98 signal too largely
17817 tank ventilation valve -N80 of electrical errors in the electric circuit
17818 tank ventilation valve -N80 short-circuit after pluses
17819 bank 2, secondary air system throughput too small
17822 bank 2, secondary air system leakage recognized
17828 secondary air injecting valve -N112 of electrical errors in the electric circuit
17829 secondary air injecting valve -N112 short-circuit after mass
17830 secondary air injecting valve -N112 short-circuit after pluses
17831 bank 1, secondary air system throughput too small
17832 bank 1, secondary air system leakage recognized
17833 tank ventilation valve -N80 short-circuit after mass
17834 tank ventilation valve -N80 interruption
17840 secondary air injecting valve -N112 interruption
17841 relays for secondary tire pump -J299 interruption
17842 relays for secondary tire pump -J299 short-circuit after pluses
17843 relays for secondary tire pump -J299 short-circuit after mass
17844 relays for secondary tire pump -J299 of electrical errors in the electric circuit
17845 valve 2 for recycling of exhaust gases -N213 short-circuit after pluses
17846 valve 2 for recycling of exhaust gases -N213 interruption/short-circuit after mass
17847 potentiometers for recycling of exhaust gases -G212 error in basic adjustment
17848 valve for recycling of exhaust gases -N18 interruption
17849 valve for recycling of exhaust gases -N18 interruption/short-circuit after mass
17850 potentiometers for recycling of exhaust gases -G212 signal too largely
17851 potentiometers for recycling of exhaust gases -G212 signal too small
17858 secondary air system short-circuit after pluses
17859 secondary air system short-circuit after mass
17860 secondary air system interruption
17889 relays for secondary tire pump 2 -J545 interruption
17890 relays for secondary tire pump 2 -J545 short-circuit after pluses
17891 relays for secondary tire pump 2 -J545 short-circuit after mass
17892 relays for secondary tire pump 2 -J545 of electrical errors in the electric circuit
17893 secondary air injecting valve 2 -N320 interruption
17894 secondary air injecting valve 2 -N320 of electrical errors in the electric circuit
17895 secondary air injecting valve 2 -N320 short-circuit after mass
17896 secondary air injecting valve 2 -N320 short-circuit after pluses
17897 tank ventilation valve 2 -N333 short-circuit after pluses
17898 tank ventilation valve 2 -N333 short-circuit after mass
17899 tank ventilation valve 2 -N333 interruption
17900 tank ventilation valve 2 -N333 of electrical errors in the electric circuit
17902 tank ventilation system 2 throughput incorrectly
17908 fuel pump relays -J17 of electrical errors in the electric circuit
17909 fuel pump relays -J17 short-circuit after mass
17910 fuel pump relays -J17 short-circuit after pluses
17911 load signal of generator clamp DF implausible signal
17912 air intake system leakage recognized
not/interruption closes 17913 throttle idle microswitches -F60
not/short-circuit opens 17914 throttle idle microswitches -F60 after mass
17915 no-load operation system learning value lower limit reaches
17916 no-load operation system learning value upper border reaches
17917 valve for no-load operation stabilization -N71 of electrical errors in the electric circuit
17918 valve for no-load operation stabilization -N71 short-circuit after pluses
17919 valve for suction tube change-over -N156 of electrical errors in the electric circuit
17920 valve for suction tube change-over -N156 short-circuit after pluses
17921 valve 2 for suction tube change-over -N261 short-circuit after pluses
17922 valve 2 for suction tube change-over -N261 short-circuit after mass
17923 valve for suction tube change-over -N156 short-circuit after mass
17924 valve for suction tube change-over -N156 interruption
17925 main relays -J271 electrical error in the electric circuit
17926 main relays -J271 short-circuit after pluses
17927 bank 1, cam shaft adjustment malfunctioning
17928 valve 2 for suction tube change-over -N261 interruption
17930 bank 2, cam shaft adjustment malfunctioning
17931 Crash signal of the Airbag controller implausible signal
17932 fuel pump relays -J17 interruption/short-circuit after mass
17934 bank 1, cam shaft adjustment -N205 short-circuit after pluses
17935 bank 1, cam shaft adjustment -N205 short-circuit after mass
17936 bank 1, cam shaft adjustment -N205 interruption
17937 cam shaft adjustment short-circuit after pluses
17938 cam shaft adjustment short-circuit after mass
17939 cam shaft adjustment interruption
17942 bank 2, cam shaft adjustment -N208 short-circuit after pluses
17943 bank 2, cam shaft adjustment -N208 short-circuit after mass
17944 bank 2, cam shaft adjustment -N208 interruption
17947 clutch pedal switches -F36 implausible signal
17948 vehicle speed signal signal too largely
17949 fuel pump relays -J17 interruption
17950 angle sensors for butterfly valve drive -G187 implausible signal
17951 angle sensors for butterfly valve drive -G187 signal too small
17952 angle sensors for butterfly valve drive -G187 signal too largely
17953 butterfly valve control malfunctioning
17954 single solenoid valve for load pressure control -N75 short-circuit after pluses
17955 single solenoid valve for load pressure control -N75 short-circuit after mass
17956 single solenoid valve for load pressure control -N75 interruption
17957 single solenoid valve for load pressure control -N75 interruption/short-circuit after mass
17958 load pressure rule difference
17961 signal elevator giver/suction tube pressure implausible relationship
17962 butterfly valve control unit -J338 conditions for basic adjustment does not fulfill
17963 maximum load pressure exceeded
17964 load pressure control rule border fell below
17965 load pressure control rule border exceeded
17966 butterfly valve drive -G186 of electrical errors in the electric circuit
17967 butterfly valve control unit -J338 error in basic adjustment
17968 maximum engine speed exceeded
17972 butterfly valve control unit -J338 undervoltage during basic adjustment
17973 butterfly valve control unit -J338 lower notice one does not reach
17976 butterfly valve control unit -J338 of mechanical errors
17977 switches for GRA -E45 implausible signal
17978 engine expensive equipment closed
17979 valve left for engine storage -N144 short-circuit after pluses
17980 valve left for engine storage -N144 short-circuit after mass
17981 valve left for engine storage -N144 interruption
17982 valve left for engine storage -N144 of electrical errors in the electric circuit
17983 valve right for engine storage -N145 short-circuit after pluses
17984 valve right for engine storage -N145 short-circuit after mass
17985 valve right for engine storage -N145 interruption
17986 valve right for engine storage -N145 of electrical errors in the electric circuit
17987 butterfly valve control unit -J338 adaptation not started
17988 butterfly valve drive bank 1 malfunctioning
17989 butterfly valve control unit -J338 basic adjustment not accomplished
17990 no-load operation adaptation border reaches
17994 valves for engine storage -N144/-N145 short-circuit after pluses
18008 voltage supply Kl. 15 tension too small
18009 relays for voltage supply clamp 30 -J317 implausible signal
18010 voltage supply Kl.30 tension too small
18011 controller defectively
18012 controller defectively
18014 bad way info./engine target moment of the ABS controller of electrical errors in the electric circuit
18017 Crashabschaltung one released
18018 controller defectively
18019 requirement error lamp a short-circuit after mass
18020 engine expensive equipment wrongly codes
18023 givers for oil temperature -G8 implausible signal
18024 indicator light for time the glow plugs are on -K29 short-circuit after pluses
18025 indicator light for time the glow plugs are on -K29 interruption/short-circuit after mass
18026 relays for glow plugs -J52 short-circuit after pluses
18027 relays for glow plugs -J52 interruption/short-circuit after mass
18031 data bus drive no communication
18032 requirement error lamp actively
18033 data bus drive implausible message of the transmission expensive equipment
18034 data bus drive missing message of the transmission expensive equipment
18036 data bus drive missing message of the giver for guidance angles
18038 givers for position of the gas pedal -G79 signal too small
18039 givers for position of the gas pedal -G79 signal too largely
18040 givers for position of the gas pedal -G79 supply voltage
18041 givers 2 for position of the gas pedal -G185 signal too small
18042 givers 2 for position of the gas pedal -G185 signal too largely
18043 data bus drive missing message of the climatic expensive equipment
18044 data bus drive missing message of the Airbag controller
18045 data bus drive missing message of electronic central electrical connection
18047 givers 1/2 for position of the gas pedal -G79 and -G185 implausible signal
18048 controller defectively
18049 request error memory of the climatic expensive equipment select
18053 data bus drive missing message of the all wheel controller
18055 coding/variants of the controllers in the drive strand examine
18056 data bus drive defectively
18057 data bus drive missing message of the ABS controller
18058 data bus drive missing message of the combination instrument
18060 request error memory of the transmission expensive equipment select
18061 request error memory of the ABS controller select
18062 request error memory of the combination instrument select
18064 air conditioning system entrance/exit short-circuit after mass
18065 air conditioning system entrance/exit short-circuit after pluses
18067 radiator exhaust control 1 short-circuit after pluses
18068 radiator exhaust control 1 short-circuit after mass
18069 radiator exhaust control 2 short-circuit after pluses
18070 radiator exhaust control 2 short-circuit after mass
18071 control of valves pump/nozzle short-circuit after pluses
18072 control of valves pump/nozzle of electrical errors in the electric circuit
18073 control of valves pump/nozzle of mechanical errors
18074 valve for pump/nozzle cylinder 1 -N240 of electrical errors in the electric circuit
18075 valve for pump/nozzle cylinder 2 -N241 of electrical errors in the electric circuit
18076 valve for pump/nozzle cylinder 3 -N242 of electrical errors in the electric circuit
18077 valve for pump/nozzle cylinder 4 -N243 of electrical errors in the electric circuit
18080 radiator exhaust control 1 interruption/short-circuit after mass
18081 geschwindigkeitssignal error message of the ABS controller
18084 error lamp for electrical gas manipulation -K132 of electrical errors in the electric circuit
18085 error lamp for electrical gas manipulation -K132 short-circuit after pluses
18086 error lamp for electrical gas manipulation -K132 short-circuit after mass
18087 error lamp for electrical gas manipulation -K132 interruption
18089 controller programming of programming does not terminate
18090 data bus drive implausible message of the ABS controller
18098 error lamp for eigendiagnose -K83 of electrical errors in the electric circuit
18099 error lamp for eigendiagnose -K83 interruption
18100 error lamp for eigendiagnose -K83 short-circuit after mass
18101 error lamp for eigendiagnose -K83 short-circuit after pluses
18112 kickdown switches -F8 of electrical errors in the electric circuit
18132 signal for starter barrier short-circuit after mass
18137 signal for starter barrier short-circuit after pluses
18141 switches for Tiptronic, back -F189 short-circuit after mass
18147 switches for Tiptronic, highly -F189 short-circuit after mass
18148 clutch overloads
18149 clutch pressure adaptation adaptation border reaches
18150 clutch moment adaptation adaptation border reaches
18151 clutch slip monitoring signal too largely
18152 switches for Tiptronic, recognition -F189 short-circuit after mass
18153 Versorgungsspannnung for single solenoid valves short-circuit after pluses
18155 Versorgungsspannnung for single solenoid valves interruption/short-circuit after mass
18156 controller defectively
18157 controller for automatic transmission wrong coding
18158 voltage supply tension too small
18159 voltage supply tension too largely
18160 voltage supply implausible signal
18169 lock-out magnet -N110 short-circuit after mass
18170 lock-out magnet -N110 short-circuit after pluses
18171 lock-out magnet -N110 interruption
18172 transmission temperature monitoring
18179 load signal from the engine expensive equipment interruption/short-circuit after pluses
18180 load signal from the engine expensive equipment short-circuit after mass
18181 givers 1 for hydraulic pressure -G193 signal too largely
18192 high/back spacing line interruption/short-circuit after mass
18193 high/back spacing line short-circuit after pluses
18194 relays for back headlight interruption
18195 signal for back headlight short-circuit after mass
18196 signal for back headlight short-circuit after pluses
18198 signal for selecting range announcement interruption
18199 signal for selecting range announcement short-circuit after mass
18200 signal for selecting range announcement short-circuit after pluses
18201 givers 2 for transmission speed -G196 no signal
18203 signal for driving speed interruption
18204 signal for driving speed short-circuit after mass
18205 signal for driving speed short-circuit after pluses
18206 givers 2 for transmission speed -G196 implausible signal
18221 pressure control valve 1 -N215 of electrical errors in the electric circuit
18222 pressure control valve 1 -N215 interruption/short-circuit after mass
18223 pressure control valve 1 -N215 short-circuit after pluses
18226 pressure control valve 2 -N216 of electrical errors in the electric circuit
18227 pressure control valve 2 -N216 interruption/short-circuit after mass
18228 pressure control valve 2 -N216 short-circuit after pluses
18232 pressure control valve 3 -N216 interruption/short-circuit after mass
18233 pressure control valve 3 -N216 short-circuit after pluses
18237 pressure control valve 4 -N216 interruption/short-circuit after mass
18238 pressure control valve 4 -N216 short-circuit after pluses
18242 pressure control valve 5 -N216 interruption/short-circuit after mass
18243 pressure control valve 5 -N216 short-circuit after pluses
18249 engine/transmission expensive equipment variants does not fit
18256 request error memory of the engine expensive equipment select
18258 data bus drive missing message of the engine expensive equipment
18259 data bus drive missing message of the ABS controller
18261 data bus drive implausible message of the ABS controller
18262 data bus drive defectively
18263 data bus drive software condition monitoring (data bus drive)
18264 butterfly valve potentiometers -G69 error message of the engine expensive equipment
18265 load signal error message of the engine expensive equipment
18266 number of revolutions of the engine expensive equipment error message of the engine expensive equipment
18269 givers for position of the gas pedal -G79 error message of the engine expensive equipment
18308 radiator exhaust control 2 interruption/short-circuit after mass
18309 controller for radiator exhaust oh run -J138 short-circuit after pluses
18310 controller for radiator exhaust oh run -J138 interruption/short-circuit after mass
18311 valve for exhaust cooling agent -N313 short-circuit after pluses
18312 valve for exhaust cooling agent -N313 interruption/short-circuit after mass
18313 relays for pump load air cooling -J536 short-circuit after pluses
18314 relays for pump load air cooling -J536 interruption/short-circuit after mass
18315 data bus engine/engine defectively
18316 data bus engine/engine software condition monitoring
18317 data bus engine/engine missing message of the engine expensive equipment 1
18318 data bus engine/engine missing message of the engine expensive equipment 2
18319 Synchonisationsleitung engine/engine of electrical errors in the electric circuit
18328 valve for engine storage -N144/145 interruption/short-circuit after mass
18331 request error memory of the engine expensive equipment 2 select
18332 controller pin coding implausible signal
18333 relays for coolant additive pump -J496 short-circuit after pluses
18334 relays for coolant additive pump -J496 short-circuit after mass
18335 relays for coolant additive pump -J496 interruption
18342 temperature sensors for drive cycle radiator exhaust -G382 signal too small
18343 temperature sensors for drive cycle radiator exhaust -G382 signal too largely
19456 indicator light for time the glow plugs are on -K29
19458 kick-down switches -F8 implausible signal
19459 relays for small amount of heat -J359 short-circuit after pluses
19461 relays for large amount of heat -J360 short-circuit after pluses
19463 cam shaft position sensor -G40 no signal
19464 cam shaft position sensor -G40 signal outside of the tolerance
19465 relays for pump, fuel cooling -J445 short-circuit after pluses
19466 relays for pump, fuel cooling -J445 interruption/short-circuit after mass
19467 relays for electrical fuel pump 2 -J49 short-circuit after pluses
19468 relays for electrical fuel pump 2 -J49 interruption/short-circuit after mass
19469 valve 2 for load pressure control -N274 short-circuit after pluses
19470 valve 2 for load pressure control -N274 interruption/short-circuit after mass
19471 valve for fuel bypass -N312 short-circuit after pluses
19472 valve for fuel bypass -N312 interruption/short-circuit after mass
19473 valve for waste gas valve 1 -N321 short-circuit after pluses
19474 valve for waste gas valve 1 -N321 short-circuit after mass
19475 valve for waste gas valve 1 -N321 interruption
19476 valve for waste gas valve 1 -N321 of electrical errors in the electric circuit
19481 angle sensors 1 signal implausible for butterfly valve drive 2 -G297
19482 angle sensors 1 for butterfly valve drive 2 -G297 signal too small
19483 angle sensors 1 for butterfly valve drive 2 -G297 signal too largely
19484 angle sensors 2 for butterfly valve drive 2 -G298 implausible signal
19485 angle sensors 2 for butterfly valve drive 2 -G298 signal too small
19486 angle sensors 2 for butterfly valve drive 2 -G298 signal too largely
19487 butterfly valve drive 2 -G296 of electrical errors in the electric circuit
19488 butterfly valve control unit 2 -J544 errors in basic adjustment
19489 givers 2 for intake air temperature -G299 signal too small
19490 givers 2 for intake air temperature -G299 signal too largely
19491 butterfly valve control unit 2 -J544 of mechanical errors
19492 butterfly valve control unit 2 -J544 undervoltage during basic adjustment
19493 butterfly valve control unit 2 -J544 adaptation not started
19494 butterfly valve control unit 2 -J544 lower notice one does not reach
19560 transfer valve for suction tube flap -N239 short-circuit after pluses
19561 transfer valve for suction tube flap -N239 interruption/short-circuit after mass
19656 exhaust bank 3, probe 1 heizstromkreis short-circuit after mass
19657 exhaust bank 3, probe 1 heizstromkreis short-circuit after pluses
19658 exhaust bank 3, probe 1 heizstromkreis interruption
19659 exhaust bank 3, probe 1 heizstromkreis of electrical errors
19662 exhaust bank 3, probe 1 tension too largely
19663 exhaust bank 3, probe 1 electrical error in the electric circuit
19664 exhaust bank 3, probe 1 no activity
19665 exhaust bank 3, probe 1 signal too slowly
19666 exhaust bank 3, probe 1 heizstromkreis achievement too small
19671 exhaust bank 3, probe 2 heizstromkreis short-circuit after mass
19672 exhaust bank 3, probe 2 heizstromkreis short-circuit after pluses
19673 exhaust bank 3, probe 2 heizstromkreis interruption
19674 exhaust bank 3, probe 2 heizstromkreis of electrical errors
19675 exhaust bank 3, probe 2 internal resistance too largely
19676 exhaust bank 3, probe 2 tension too small
19677 exhaust bank 3, probe 2 tension too largely
19678 exhaust bank 3, probe 2 electrical error in the electric circuit
19679 exhaust bank 3, probe 2 no activity
19680 exhaust bank 3, probe 2 signal too slowly
19686 exhaust bank 4, probe 1 heizstromkreis short-circuit after mass
19687 exhaust bank 4, probe 1 heizstromkreis short-circuit after pluses
19688 exhaust bank 4, probe 1 heizstromkreis interruption
19689 exhaust bank 4, probe 1 heizstromkreis of electrical errors
19692 exhaust bank 4, probe 1 tension too largely
19693 exhaust bank 4, probe 1 electrical error in the electric circuit
19694 exhaust bank 4, probe 1 no activity
19695 exhaust bank 4, probe 1 signal too slowly
19696 exhaust bank 4, probe 1 heizstromkreis achievement too small
19701 exhaust bank 4, probe 2 heizstromkreis short-circuit after mass
19702 exhaust bank 4, probe 2 heizstromkreis short-circuit after pluses
19703 exhaust bank 4, probe 2 heizstromkreis interruption
19704 exhaust bank 4, probe 2 heizstromkreis electrical error
19705 exhaust bank 4, probe 2 internal resistance too largely
19706 exhaust bank 4, probe 2 tension too small
19707 exhaust bank 4, probe 2 tension too largely
19708 exhaust bank 4, probe 2 electrical error in the electric circuit
19709 exhaust bank 4, probe 2 no activity
19710 exhaust bank 4, probe 2 signal too slowly
19716 exhaust bank 1/2 Lambda probes before Kat exchanges
19717 exhaust bank 3/4 Lambda probes before Kat exchanges
19718 exhaust bank 1/2 Lambda probes after Kat exchanges
19719 exhaust bank 3/4 Lambda probes after Kat exchanges
19720 Vorkatalysator exhaust bank 3 effect too small
19721 Vorkatalysator exhaust bank 4 effect too small
19756 bank 1, cam shaft position sensor, discharge opening -G300 short-circuit after mass
19757 bank 1, cam shaft position sensor, discharge opening -G300 interruption/short-circuit after pluses
19758 bank 2, cam shaft position sensor, discharge opening -G301 short-circuit after mass
19759 bank 2, cam shaft position sensor, discharge opening -G301 interruption/short-circuit after pluses
19760 bank 1, exhaust cam wave position sensor -G300/crankshaft position sensor -G28 wrong allocation
19761 bank 2, exhaust cam wave position sensor -G301/crankshaft position sensor -G28 wrong allocation
65535 controller defectively
Error kinds:
01-00 short-circuit after pluses
02-00 short-circuit after mass
03-00 no signal
04-00 mechanical error
05-00 entrance openly
06-00 signal too largely
07-00 signal too small
08-00 rule border exceeded
09-00 adaptation border exceeded
10-00 adaptation border fell below
11-00 rule border fell below
12-00 adaptation border (mul.) exceeded
13-00 adaptation border (mul.) fallen below
14-00 adaptation border (ADD.) exceeded
15-00 adaptation border (ADD.) fallen below
16-00 signal outside of the tolerance
17-00 rule difference
18-00 upper notice value
19-00 lower notice value
20-00 errors in basic adjustment
21-00 time for pressure build-up in front too long
22-00 time for pressure drop in front too long
23-00 time for pressure build-up in the back too long
24-00 time for pressure drop in the back too long
25-00 undefined switch condition
26-00 exit openly
27-00 implausible signal
28-00 short-circuit after pluses
29-00 short-circuit after mass
30-00 interruption/short-circuit after pluses
31-00 interruption/short-circuit after mass
32-00 resistance value too largely
33-00 resistance value too small
34-00 no error recognized
35-00
36-00 interruption
37-00 defectively
/ short-circuit does not switch 38-00 exit after pluses
/ short-circuit does not switch 39-00 exit after mass
40-00 short-circuit to other valve
41-00 blocks or without tension
42-00 number of revolutions deviation too largely
43-00 closed
44-00 short-circuit
45-00 patch cord
46-00 leaky
47-00 wrongly attached
48-00 voltage supply
49-00 no communication
50-00 position early does not reach
51-00 position late does not reach
52-00 voltage supply too largely
53-00 voltage supply too small
54-00 wrong equipment
55-00 adaptation does not take place
56-00 in the fail-safe
57-00 electrical error in the electric circuit
58-00 does not lock
59-00 does not unlock
60-00 safed not
61-00 entsafed not
62-00 no or wrong attitude
63-00 temperature disconnection
67-00 desired value does not reach
68-00 cylinders 1
69-00 cylinders 2
70-00 cylinders 3
71-00 cylinders 4
72-00 cylinders 5
73-00 cylinders 6
74-00 cylinders 7
75-00 cylinders 8
is missing to 76-00 clamp 30
77-00 internal voltage supply
78-00 missing messages
79-00 please error memory select
80-00 in the single-wire enterprise
81-00 openly
82-00 released
192-00 at present not controllably
193-00 not entitled
194-00 alignment not accomplished
Boas, mas isto é os erros do vag e a sua possivel resolução?
Existe um site que é o ross tech, que diz os erros todos, a sua causa e sintomas.
Mas de qualquer das maneiras bom post que crias-te:)
Exactamente, mas nem toda a gente sabe...é apenas uma ajuda =)
