Erros vag.com(resolvido)
Boas pessoal.
Estou com uns erros no vag com, mas apenas me aparece o erro pois instalei o vag noutro PC e nao sei da chave de activação, logo nao me aparece a descriçao e so me aparece apenas o erro em questao. será que me podem dizer o que é ?
Erros: ( RESOLVIDO )
16955
18080
18058
17552 - Mass Air Flow Sensor (resolvido - esta anulado electronicamente )
Se me puderem dar a descriçao de cada erro em portugues agradecia sff.
Boas pessoal, alguem me pode dar uma ajuda com estes erros duma Ibiza 6L PD130
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 E
Component: CLIMAtronic PQ24 3805
Shop #: WSC 00000 000 00000
VCID: 285BFC9398E804E
28 Faults Found
01297 - Sensor for Vent Temperature; Footwell (G192)
007 - Short to Ground - Intermittent
010 - Open or Short to Plus - Intermittent
01296 - Sensor for Vent Temperature; Center (G191)
00818 - Sensor for Evaporator Outlet Temperature (G263)
00797 - Sunlight Photo Sensor (G107)
01271 - Positioning Motor for Temperature Flap (V68)
000 - - - Intermittent
01272 - Positioning Motor for Central Flap (V70)
01274 - Air Flow Flap Positioning Motor (V71)
00576 - Terminal 15
001 - Upper Limit Exceeded - Intermittent
00538 - Reference Voltage
002 - Lower Limit Exceeded - Intermittent
00792 - A/C Pressure Switch (F129)
00819 - High Pressure Sensor (G65)
00898 - Control Circuit A/C compressor
00705 - Relay for Coolant Fan; Stage 1 (J279)
009 - Open or Short to Ground - Intermittent
006 - Short to Plus - Intermittent
00706 - Relay for Coolant Fan; Stage 2 (J513)
01233 - Engine Coolant Blocking Valve for Heater (N279)
00457 - Control Module for Network (J519)
004 - No Signal/Communication - Intermittent
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
01336 - Data Bus for Comfort System
014 - Defective - Intermittent
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 02QT GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 06402
VCID: F0EB54F3B0B88CE
Note: Excessive Comm Errors
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
É que eu a ingles precebo pouco :/
Obrigado!
pessoal uma ajuda neste, depois de metida maf nova (pierburg):
1 Fault Found:
17553 - Mass Air Flow Sensor (G70)
P1145 - 35-10 - Short to Plus - Intermittent
Readiness: 0 0 1 1 1
