Erros VAG-com Ajuda
Boas pessoal, sou novo nestas andanças do vag-com por isso coloco aqui as minhas duvidas para k me possam ajudar... Comprei o cabo a pouco tempo e fui ligar num leon que o meu pai tinha na oficina, e deram estes erros:
VCDS Version: Beta 812.4
Data version: 20090214
Thursday,01,January,2009,15:46:16:26365
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ9R011090 Mileage: 52970km/32914miles
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 056 AA HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 2898
Revision: --H08--- Serial number: SEX7Z0H531A0G8
Coding: 0050071
Shop #: WSC 06402 785 00200
2 Faults Found
013112 - Control Circuit for Glow Plug Controller 1: Electrical Malfunction
P3338 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 2
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001100
Temperature: 18.0°C
Bin. Bits: 00110000
005441 - Fuel Pump Relay (J17): Open Circuit
P1541 - 000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001100
Bin. Bits: 0
(no units): 0.0
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 113B2012092300FB880B04ED901900413400
Shop #: WSC 04941 000 00000
1 Fault Found
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 52977 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 0
Count: 12288
Count: 8194
Count: 43520
Count: 65280
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
1 Fault Found
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000005777589
Coding: 41880F2F00041000431D00000000000000017F075C40000000 0000000000
Part No: 1P0 955 559
Component: REGENLICHTSENSORH04 0090
Coding: 00152622
Shop #: WSC 06402
Component: Fehler Lin-Slave 01
8 Faults Found
01505 - Bulb for Blinkers; Rear Right (M
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 52977 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.05 V
ON
ON
OFF
OFF
OFF
00988 - Lamp for Brake Light; Right (M10)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 3
Reset counter: 22
Mileage: 52978 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 52979 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.30 V
OFF
ON
OFF
OFF
OFF
02071 - Local Databus
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 7
Reset counter: 237
Mileage: 52979 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 52979 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.95 V
ON
ON
OFF
OFF
OFF
00059 - Terminal 30 for Interior Lighting
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 22
Mileage: 52979 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.30 V
OFF
OFF
OFF
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 237
Mileage: 52979 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
00926 - Terminal 30
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 52979 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 5.00 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A02 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPB76E13
Coding: 0012338
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0002042
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 827 E
Component: KOMBIINSTRUMENT VO3 0450
Coding: 0002101
Shop #: WSC 15614 784 88726
1 Fault Found
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0860401BC
Coding: E9807F060002020202
2 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 21
Mileage: 52977 km
Time Indication: 0
Date: 2000.00.00
Time: 13:23:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 52979 km
Time Indication: 0
Date: 2000.00.00
Time: 15:24:09
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VO3 0450
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1517
Revision: 71009005 Serial number: 00000003488504
Coding: 0004272
2 Faults Found
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 52979 km
Time Indication: 0
00943 - Heated Exterior Mirror; Driver Side (Z4)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 198
Reset counter: 237
Mileage: 35329 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.077 H08 1901
1 Fault Found
Freeze Frame:
Mileage: 52970 km
Temperature: 19.0°C
Voltage: 12.10 V
Voltage: 11.90 V
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 988000005283CC7F0006850560084F01207C80
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1517
Revision: 71009005 Serial number: 00000629788507
Coding: 0004272
2 Faults Found
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 52979 km
Time Indication: 0
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 97
Reset counter: 237
Mileage: 49009 km
Time Indication: 0
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0006
Coding: 0040424
Address 62: Door,Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11006001 Serial number: 00000003178710
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11006001 Serial number: 00000003181468
Coding: 0000144
End ---------------------------------------------------------------------
Agora a minha duvida é a seguinte: o que significam esses erros e como posso resolve-los. Sei que o carro ta com problemas como: os piscas do lado direito não funcionam e as escovas da frente tb n....
Espero ajuda
Abraço[-o<
Pelo que tive a ver deve ser algum fusível marada, os erros são todos falha electrica, ou fusível ou ficha de ligação.
Muda o fusível e limpa com wd40 as fichas.
Espero ter ajudado.
