Erros VAG-COM 6k2
Comprei o vag-com e no primeiro scan geral que faço ao meu 6k2 110 sport, os erros que me apareceram foram os seguintes:
Chassis Type: 6K - Seat Ibiza/Cordoba
Scan: 01 02 03 08 15 17 25 45 56
Mileage: 226070km/140473miles
Address 01: Engine Labels: None
Part No: 038 906 018 FB
Component: 1,9l R4 EDC 0200SG 2167
Coding: 00005
Shop #: WSC 00001
VCID: 5BB1935FE3B5
5 Faults Found:
01282 - Intake Manifold Flap change-over Valve (N239)
31-10 - Open or Short to Ground - Intermittent
17849 - EGR Valve (N18): Open Circuit or Short to Ground
P1441 - 35-10 - - - Intermittent
00741 - Brake Pedal Monitoring
27-00 - Implausible Signal
17569 - Manifold Temp Sensor (G72): Open or Short to Plus
P1161 - 35-00 - -
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
P1156 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 R
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 11111
VCID: 408B44336A13
No fault code found.
Address 08: Auto HVAC Labels: 6K0-959-291.lbl
Part No: 6K0 959 291
Component: AUTOCLIMA-220 X03.01
VCID: F4E358E3EE2B
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: N AIRBAG VW3 SG 0002
Coding: 00078
Shop #: WSC 06402
VCID: ECD34083B61B
Address 17: Instruments Labels: 6K0-920-xxx-17.lbl
Part No: 6K0 920 850 F
Component: 6K-KOMBIINSTR. VDO V05
Coding: 00142
Shop #: WSC 00000
VCID: 2F69178FC78D
Part No: IMMO
Component: IDENTNR: SEZ7Z0X0244814
IMMO-IDENTNR: SEZ7Z0X0244814
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 6K0 035 186 C
Component: Radio GRO 1V32
Coding: 00401
Shop #: WSC 06402
VCID: 2B51039FF395
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End ---------------------------------------------------------------------
depois de correr a correcção dos erros fiz novamente um log e os que permaneceram fora os seguintes:
Monday,04,July,2011,21:07:58:10074
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Coding: 00005
Shop #: WSC 00001
VCID: 5BB1935FE3B5
2 Faults Found:
Readiness: N/A
Coding: 13404
Shop #: WSC 11111
VCID: 408B44336A13
VCID: F4E358E3EE2B
Coding: 00078
Shop #: WSC 06402
VCID: ECD34083B61B
Coding: 00142
Shop #: WSC 00000
VCID: 2F69178FC78D
Part No: IMMO
Coding: 00401
Shop #: WSC 06402
VCID: 2B51039FF395
principlmente na parte do engine apareceram mts erros. ja vi o que significam os codigos, mas fiquei a zero na mesma em relação à sua solução.
alguem ajude.....
