boas pessoal, ontem acendeu me a luz de motor, liguei o vag com e apareceu me la estes erros alguem ajuda...
Address 01: Engine
Part No: 036 906 034 DG
Component: MARELLI 4MV G 5953
Coding: 00071
Shop #: WSC 06402
VSSZZZ6LZ5R125474 SEZ7Z0E2863211
1 Fault Found:
16555 - Fuel Trim; Bank 1: System Too Lean
P0171 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Part No SW: 6Q0 907 379 AA HW: 6Q0 907 379 AA
Component: ABS 8.0 front H03 0001
Coding: 0000005
Shop #: WSC 06403
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 63
Mileage: 67620 km
Time Indication: 0
Address 09: Cent. Elect.
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 16396
Shop #: WSC 06402
5 Faults Found:
49-10 - No Communications - Intermittent
01309 - Power Steering Control Module (J500)
01316 - ABS Control Module
01598 - Drive Battery Voltage
27-10 - Implausible Signal - Intermittent
01054 - Power Supply Relay; Terminal 30 (J317)
28-10 - Short to Plus - Intermittent
Address 17: Instruments
Part No: 6L0 920 801 C
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 00145
Shop #: WSC 00000
3 Faults Found:
Address 19: CAN Gateway
Part No: 6N0 909 901
Component: 0068 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
3 Faults Found:
Address 01: Engine
Coding: 00071
Shop #: WSC 06402
1 Fault Found:
P0171 - 35-00 - -
Coding: 0000005
Shop #: WSC 06403
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 63
Mileage: 67620 km
Time Indication: 0
Coding: 16396
Shop #: WSC 06402
5 Faults Found:
Coding: 00145
Shop #: WSC 00000
3 Faults Found:
Coding: 00014
Shop #: WSC 06402
3 Faults Found:
