erros depois de instalar o cc
boas, o trabalho não foi feito num Ibiza mas é um vag também
eu instalei ontem o cc no meu skoda octavia e depois de instalado aparece estes erros
o do sensor de temperatura motor e ac já são contínuos, os outros apareceram depois de instalar o cc
o cc esta a funcionar bem, já o experimentei e já fui a mesureblock no canal 006 e tudo esta ok, desde botões a sensor pedal de travão e embraiagem
Chassis Type: 1U - Skoda Octavia I
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
VIN: TMBBG21U512452842 Mileage: 344720km/214199miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 H
Component: 1,9l R4 EDC G020SG 3315
Coding: 00002
Shop #: WSC 31480
VCID: 152BDF8D6F9AB71
TMBBG21U512452842 SKZ7Z0Y0643587
2 Faults Found:
17664 - Engine Coolant Temp Sensor (G62)
P1256 - 35-10 - Open or Short to Plus - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-00 -
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 31480 000 00000
VCID: 2B5F1975891E111
No fault code found.
Address 08: Auto HVAC Labels: 1Ux-907-044.lbl
Part No: 1U1 907 044 A
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 31480
VCID: 30650E19F038729
2 Faults Found:
00792 - A/C Pressure Switch (F129)
35-00 - -
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605
Component: 08 AIRBAG VW5 0004
Coding: 12344
Shop #: WSC 31480
VCID: F4ED4209C4A08E9
Address 17: Instruments Labels: 1U0-920-xxx-17.lbl
Part No: 1U0 920 921 G
Component: KOMBI+WEGFAHRSP VDO V08
Coding: 02122
Shop #: WSC 31480
VCID: 346D020904204E9
1 Fault Found:
01336 - Data Bus for Comfort System
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
VCID: F0E54E19B0B8B29
1 Fault Found:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 7R Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 31480
VCID: 840D12C99400BE9
Subsystem 1 - Part No: 1U4959801B
Component: 7R Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1U4959802B
Component: 7R Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1U0959811B
Component: 7R Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1U0959812B
Component: 7R Tõrsteuerger. HR0002r
End ---------------------------------------------------------------------
