joão6ltdipd130
Utilizador Banido
BOAS TENHO UM IBIZA 6L TDI PD 130CV
queria saber se alguem pode ajudar e dizer o que tenho de susbstituir no carro conssoante o seguinte relatorio de erros :
Address 01: Engine Labels: 038-906-019-130.LBL
Part No: 038 906 019 DQ
Component: 1,9l R4 EDC G400SG 1536
Coding: 00002
Shop #: WSC 12345
VSSZZZ6LZ3R134625 SEZAZ0B3300021
1 Fault Found:
17849 - EGR Valve (N18): Open Circuit or Short to Ground
P1441 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: None
Part No: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V20
Coding: 00188
Shop #: WSC 06403
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 045
Component: Klimaanlage X0840
11 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
01271 - Positioning Motor for Temperature Flap (V68)
29-10 - Short to Ground - Intermittent
30-10 - Open or Short to Plus - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
41-10 - Blocked or No Voltage - Intermittent
28-10 - Short to Plus - Intermittent
00819 - High Pressure Sensor (G65)
31-00 - Open or Short to Ground
00898 - Control Circuit A/C compressor
30-00 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.LBL
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 00652
Shop #: WSC 06402
1 Fault Found:
01024 - Rain Sensor (G213)
03-00 - No Signal
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Part No: 6Q0 909 605 S
Component: 14 AIRBAG VW5 07 0007
Coding: 12596
Shop #: WSC 06441
12 Faults Found:
00595 - Crash Data Stored
35-00 - -
01226 - Crash Data Stored for Side Airbag; Driver Side
35-00 - -
01214 - Crash Data for Belt Tensioner Stored
35-00 - -
00532 - Supply Voltage B+
07-00 - Signal too Low
01218 - Side Airbag Igniter; Passenger Side (N200)
00-00 - -
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
32-10 - Resistance too High - Intermittent
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00589 - Airbag Igniter 1; Passenger Side (N131)
00588 - Airbag Igniter; Driver Side (N95)
33-10 - Resistance too Low - Intermittent
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
36-10 - Open Circuit - Intermittent
Address 17: Instruments Labels: None
Part No: 6L0 920 830 K
Component: KOMBI+WEGFAHRSP TRW V01
Coding: 00145
Shop #: WSC 06402
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: 60 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06402
Address 44: Steering Assist Labels: None
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 10110
Shop #: WSC 00000
End --------------------------------------------------------------------------------------------------
Fornecido pelo VAG-COM
cumpz e obrigado
Coding: 00002
Shop #: WSC 12345
1 Fault Found:
Coding: 00188
Shop #: WSC 06403
11 Faults Found:
00-00 - -
Coding: 00652
Shop #: WSC 06402
1 Fault Found:
03-00 - No Signal
Coding: 12596
Shop #: WSC 06441
12 Faults Found:
35-00 - -
35-00 - -
35-00 - -
00-00 - -
Coding: 00145
Shop #: WSC 06402
1 Fault Found:
Coding: 00014
Shop #: WSC 06402
Coding: 10110
Shop #: WSC 00000
cumpz e obrigado
