Bom Passei co o Vag Com.. e este foi o resultado
VAG-COM Version: Release 311.2-N
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Controller: 038 906 018 P
Component: 1,9l R4 EDC 40SG 1629
Coding: 00002
Shop #: WSC 00045
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 A
Component: CLIMATRONIC S 9.0
Coding: 02000
Shop #: WSC 05314
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 3B0 919 881 N
Component: B5-KOMBIINSTR. VDO V34
Coding: 04140
Shop #: WSC 26144
IMMO-IDENTNR: VWZ7Z0W0667453
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 0E Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 76678
1 Fault Found:
00930 - Locking Module for Central Locking: Rear Left (F222)
27-00 - Implausible Signal
Address 56 -------------------------------------------------------
Controller: 1J0 035 186 B
Component: Radio 0001
Coding: 05401
Shop #: WSC 05311
2 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
36-00 - Open Circuit
00853 - Loudspeaker(s): Rear
End -------------------------------------------------------
