ajuda para erros VAG-COM 6L
deixo os erros de vag com que obtive a pouco:
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Controller: 045 906 019 BQ
Component: 1,4l R3 EDC G000SG 7627
Coding: 00102
Shop #: WSC 06402
XXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXX
1 Fault Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 AF
Component: ABS 8.0 front H05 0002
Coding: 0002199
Shop #: WSC 06402
1 Fault Found:
00526 - Brake Light Switch-F
011 - Open Circuit
Address 08 -------------------------------------------------------
Controller: 6L0 820 043 E
Component: CLIMAtronic PQ24 3805
Coding: 0000000
Shop #: WSC 00000
1 Fault Found:
00792 - A/C Pressure Switch (F129)
000 - - - Intermittent
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00140
Shop #: WSC 06402
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 823 C
Component: KOMBIINSTRUMENT AGD V01
Coding: 00102
Shop #: WSC 28242
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 0069 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10111
Shop #: WSC 06402
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00018
Shop #: WSC 06402
3 Faults Found:
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-00 - Implausible Signal
00931 - Locking Module for Central Locking: Rear Right (F223)
00849 - S-contact at Ignition/Starter Switch (D)
25-00 - Unknown Switch Condition
End -------------------------------------------------------
podem me ajudar?!?!
Esses erros são permanentes? se não forem, experimenta apagar, andas com o carro 2 dias e depois posta aqui o que apareceu.
Alguns erros por vezes aparecem por problemas de picos de corrente
boas,
apaguei os erros e depois passado uns dias andei com o carro e apenas reapareceram os erros de Locking Module for Central Locking
deve ser o fecho central :S
