Boas Pessoal
Tenho uma Fr de 2005 e meti as esferas na Egr para ela deixar de funcionar, mas apareceu a luz das avarias, entao arraneji o vag e deu-me esta lista toda, mas nao carreguei em clear que nao percebo nada e tinha medo de carregar.
A lista que me apareceu foi esta, alguem me explica isto, ou ajuda.
Data version: 20091201
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ5R139263 Mileage: 122230km/75950miles
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 NF
Component: 1,9l R4 EDC 0000SG 7000
Coding: 00102
Shop #: WSC 06402
VSSZZZ6LZ5R139263 SEZ7Z0D2799301
2 Faults Found:
19586 - EGR System: Regulation Range Exceeded
P3130 - 35-10 - - - Intermittent
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP.lbl
Part No SW: 6Q0 907 379 T HW: 6Q0 907 379 T
Component: ESP 8.0 front H03 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0000290
Shop #: WSC 06403 785 00200
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 11
Reset counter: 27
Mileage: 122090 km
Time Indication: 0
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 B
Component: CLIMAtronic PQ24 0301
Shop #: WSC 00000 000 00000
No fault code found.
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00396
Shop #: WSC 06402
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 AE
Component: 0E AIRBAG VW5 07 0010
Coding: 12357
Shop #: WSC 06401
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 820 P
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 00145
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0068 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10121
Shop #: WSC 06402
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 0R Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
Part No: 6Q2959802C
Component: 0R Tõrsteuer.FS KLO 0202
Part No: 6Q2959801C
Component: 0R Tõrsteuer.BF KLO 0202
Address 55: Xenon Range Labels: None
Part No: 6N0 907 503
Component: Leuchtweiteregelung 0005
Coding: 00012
Shop #: WSC 06402
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 6L0 035 156 B
Component: seat s04 GRO 3 99
Coding: 00401
Shop #: WSC 06402
End ------------------------------------------------
E nao consegui eliminar a EGR, fiz o processo tudo como esta aqui no forum, mas o save não dava para carregar, so consegui carregar em test.
Pessoal ajudem lá quem nao percebe nada disto.:lol:
Coding: 00102
Shop #: WSC 06402
2 Faults Found:
Coding: 0000290
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 27
Mileage: 122090 km
Time Indication: 0
Coding: 00396
Shop #: WSC 06402
Coding: 12357
Shop #: WSC 06401
1 Fault Found:
Coding: 00145
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 06402
Coding: 10121
Shop #: WSC 06402
Coding: 00064
Shop #: WSC 06402
Part No: 6Q2959802C
Part No: 6Q2959801C
Coding: 00012
Shop #: WSC 06402
Coding: 00401
Shop #: WSC 06402
