Adquiri recentemente um cabo vag 11.11 e tive a fazer um AUTOSCAN nos carros cá de casa.
gostava de uma ajuda para decifrar o resultado.
A quem quiser ajudar agradeço.
seguem os LOGS
LOG IBIZA 6J
VCDS Version: Release 11.11.0
Data version: 20111111
Sunday,24,March,2013,11:15:09:37412
Chassis Type: 6N0
Scan: 01 03 08 09 10 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZ9R034833
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 03G 906 013 K HW: 03G 906 013 K
Component: R4 1,9L EDC G000SG 2940
Revision: --H04--- Serial number:
Coding: 0053071
Shop #: WSC 66565 257 00032
VCID: 285589049BE804E
1 Fault Found:
050210 - Implausible Data Received from Body Control Module (Central Electric)
U0422 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 3
Mileage: 66654 km
Time Indication: 0
Freeze Frame:
RPM: 1092 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 11001100
Bin. Bits: 11000000
(no units): 255.0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 6J0-907-37x-ESP.clb
Part No SW: 6R0 907 379 H HW: 6R0 907 379 H
Component: ESP8.2i front H04 0005
Revision: --------
Coding: 110248DB017000B6882D12E580D400421300
Shop #: WSC 04941 000 00000
VCID: 438F3EA8C68EC76
No fault code found.
Address 08: Auto HVAC Labels: None
Part No SW: 6J0 820 043 HW: 6J0 820 043
Component: Climatronic H07 0203
VCID: E1C35420F852356
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 09: Cent. Elect. Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 HW: 6R0 937 087
Component: PQ25 BCM H06 PQ25 BCM H06 00110011
Coding: 7D882BA8C8F3250093300000760B1EC80080400F608C00002000
Shop #: WSC 64564 324 38760
VCID: FAF1034C75C4C6E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 27060
Coding: 07012D
Subsystem 2 - Part No: 6R0 959 801 A Labels: 6R0-959-801.CLB
Component: J386__TSG_FT
Coding: 020000
Subsystem 3 - Part No: 6R0 959 802 C
Component: J387__TSG_BT
Coding: 020000
Subsystem 4 - Part No: 1K8 951 171 A
Component: DWA-Sensor
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 D
Component: LIN BACKUP HO
Coding: 000000
Subsystem 6 - Part No: 1K8 951 171 A
Coding: 000000
Subsystem 7 - Part No: 6R0 959 811
Component: J388__TSG_HL
Coding: 000000
Subsystem 8 - Part No: 6R0 959 812
Component: J389__TSG_HR
Coding: 000000
No Faults Found
Address 10: Park/Steer Assist (J446) Labels: 6J0-919-475.clb
Part No SW: 6J0 919 475 HW: 6J0 919 475
Component: PARKHILFE 4K H07 0006
Revision: -------- Serial number: 80330817600801
Coding: 000002
Shop #: WSC 06403 785 00200
ASAM Dataset: EV_SE250ParkiAssis2 S01005
ROD: EV_SE250ParkiAssis2.rod
VCID: F3EF2E685AAEB76
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 HW: 6R0 959 655
Component: VW10AirbagA02 H07 0013
Revision: -------- Serial number: 003000000000
Coding: 003032
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: FF07F25866E6E36
Crash sensor for side airbag; driver side:
Serial number: 3492ERB40215K882US8E
Crash sensor for side airbag; passenger side:
Serial number: 3502ERB401V5K882TJBS
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 800 L HW: 6J0 920 800 L
Component: KOMBI 017 0018
Serial number: 00000000000000
Coding: 110A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2F6762187606536
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0011
Coding: 022200
VCID: F0E5216423B88CE
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO 017 0018
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10111
Shop #: WSC 06403
VCID: EDDB3810A08A616
Address 4B: Multifunc. Module Labels: None
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: F0E52164E3B88CE
Address 56: Radio (J503) Labels: 6J0-035-153.clb
Part No SW: 6J0 035 153 B HW: 6J0 035 153 B
Component: Radio G3 UL H55 0033
Revision: 0H001001 Serial number: SEZ1Z2H5677936
Coding: 0503040002
VCID: 234F9E2822CEE76
End ---------------------------------------------------------------------
LOG IBIZA 6L
Sunday,24,March,2013,15:33:53:37412
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ2R015599 Mileage: 135450km/84164miles
Address 01: Engine Labels: 038-906-019-AXR.lbl
Part No: 038 906 019 HQ
Component: 1,9l R4 EDC 0000SG 1502
Coding: 00002
Shop #: WSC 06402
VCID: 6DDBB810278AE16
VSSZZZ6LZ2R015599 SEZ7Z0A1474689
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.lbl
Part No: 6Q0 907 379 G
Component: ABS 5.7 FRONT V20
Coding: 00044
Shop #: WSC 00000
VCID: 418334A04B92D56
Part No: 6L0 820 043 A
Component: CLIMAtronic PQ24 0201
Shop #: WSC 00000 000 00000
VCID: 244D9D34E4C0E0E
4 Faults Found:
00818 - Sensor for Evaporator Outlet Temperature (G263)
010 - Open or Short to Plus
00710 - Defroster Flap Positioning Motor (V107)
000 - - - Intermittent
01272 - Positioning Motor for Central Flap (V70)
01274 - Air Flow Flap Positioning Motor (V71)
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.lbl
Part No: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 00140
Shop #: WSC 06402
VCID: 3A71434C264486E
2 Faults Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
00907 - Intervention load Management
35-00 - -
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 S
Component: 06 AIRBAG VW5 02 0007
Coding: 22838
Shop #: WSC 06441
VCID: 47972AB865B6EB6
1 Fault Found:
00532 - Supply Voltage B+
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 820 J
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 00142
Shop #: WSC 00000
VCID: 31636460FB32456
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 06402
VCID: F0E52164B0B88CE
Part No: 6Q0 423 156 L
Component: LenkhilfeKYO V710
Coding: 00111
Shop #: WSC 06402
VCID: 38755944184894E
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 4x Komfortgerát 0001
Coding: 00064
Shop #: WSC 06402
VCID: 3D7B4850376AB16
Subsystem 1 - Part No: 6Q2959802A
Component: 4x Tõrsteuer.FS KLO 0001
Subsystem 2 - Part No: 6Q2959801A
Component: 4x Tõrsteuer.BF KLO 0001
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 6L0 035 156
Component: seat s04 GRO 0 67
Coding: 00401
Shop #: WSC 06402
VCID: E6C9473C827C52E
seguem os LOGS
LOG IBIZA 6J
Chassis Type: 6N0
Coding: 0053071
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 66654 km
Time Indication: 0
Freeze Frame:
RPM: 1092 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 11001100
Bin. Bits: 11000000
(no units): 255.0
Revision: --------
No Faults Found
Coding: 07012D
Coding: 020000
Coding: 020000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 000000
No Faults Found
Coding: 000002
Coding: 003032
Coding: 110A00
Coding: 022200
Serial number:
Coding: 10111
Shop #: WSC 06403
Coding: 0000001
Coding: 0503040002
LOG IBIZA 6L
Coding: 00002
Shop #: WSC 06402
Coding: 00044
Shop #: WSC 00000
4 Faults Found:
Coding: 00140
Shop #: WSC 06402
2 Faults Found:
35-00 - -
Coding: 22838
Shop #: WSC 06441
1 Fault Found:
Coding: 00142
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 06402
Coding: 00111
Shop #: WSC 06402
Coding: 00064
Shop #: WSC 06402
Coding: 00401
Shop #: WSC 06402
