Ajuda Com Erros ibiza 6L
Boas
Fiz um swap de 1.4Tdi para 1.9Tdi e tenho os seguintes erros no carro:
18027 - Glow Plug Relay (J52)
P1619 - 35-10 - Open or Short to Ground - Intermittent
19561 - Valve for Intake Manifold Flap (N239)
P3105 - 35-10 - Open or Short to Ground - Intermittent
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H05 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002199
Shop #: WSC 04941 785 00200
VCID: 8109E38FDBFC51161BD-5072
2 Faults Found:
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 153347 km
Time Indication: 0
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 64
Reset counter: 75
Mileage: 153621 km
Time Indication: 0
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 F
Component: 000B BN-SG. 2S36
Coding: 08332
Shop #: WSC 04941
VCID: 3E73D8733A826EEEA6F-5072
1 Fault Found:
01044 - Control Module Incorrectly Coded
35-00 - -
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0305 GATEWAY CAN 2S36
Coding: 00012
Shop #: WSC 12345
VCID: F0EFB64BB056489EE43-5072
1 Fault Found:
35-00 - -
Alguém que me possa dar uma ajuda a resolver?
já os apagaste? volta a aparecer? tive erros semelhantes quando queimou.me a ecu do 6l..aparecia sempre:
verifica a ficha da ecu, humidades ou algo parecido
