Ajuda com Erro ABS
Boas
Recentemente começou-me a acender a luz do ESP, quando ligava o Vag Com aparece este erro:
1 Fault Found
00526 - Brake Light Switch-F
008 - Implausible Signal - Intermittent
Freeze Frame
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 98
Mileage: 93896 km
Time Indication: 0
Hoje troquei a válvula por uma nova, mas está igual!
Alguém consegue dar umas dicas??
Resul
00526 - Brake Light Switch (F): Circuit Malfunction
Possible Symptoms
MIL (Malfunction Indicator Light)
No Brake Lights
Possible Causes
Wiring and/or connections faulty between Brake Switch, Brake Lights and/or ABS Controle Module
Brake Light Switch (F) damaged
Brake Light faulty
Fuse(s) faulty
Possible Solutions
Check wiring and connections
Replace Brake Light Switch (F)
Check / Replace fuses(s)
Check / Replace Brake Lights
Check Brake Light Switch (F) in ABS Measuring Block
Special Notes
FAQ 2.7. Many Automatic Transmission Control Modules will show a DTC 00526 or 17087 that indicates a faulty brake light switch. This can be ignored and will not appear if you press the brakes once before checking for Fault Codes.
00526 - Brake Light Switch (F): Implausible Signal
Possible Causes
Wiring/Connectors from/to Brake Light Switch (F) faulty
Possible Solutions
Check/Repair Wiring/Connectors from/to Brake Light Switch (F)
Check/Replace Brake Light Switch (F)
Check Measuring Value Blocks (MVB)
Special Notes
Result
Possible Symptoms
No Brake Lights
Possible Causes
Brake Light faulty
Fuse(s) faulty
Possible Solutions
Special Notes
Boas
Obrigado pela ajuda, vou ver o que consigo fazer!
Já agora onde foste buscar essa informação dos erros?
