Erros vag com
Boas malta,
sera k alguem me pode dizer o k significam estes erros todos?
aqui fica o scan k fiz
VCDS Version: Release 10.6.0
Data version: 20100630
Saturday,29,January,2011,17:40:37:46862
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ5R188325 Mileage: 85820km/53326miles
Address 01: Engine Labels: 045-906-019-AMF.lbl
Part No: 045 906 019 BG
Component: 1,4l R3 EDC 0000SG 5180
Coding: 00105
Shop #: WSC 06402
VCID: 5BBE9532A57F96C4
VSSZZZ6LZ5R188325 SEZ7Z0E2937825
2 Faults Found
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent
19586 - EGR System: Regulation Range Exceeded
P3130 - 35-10 - - - Intermittent
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS.lbl
Part No SW: 6Q0 907 379 AA HW: 6Q0 907 379 AA
Component: ABS 8.0 front H03 0001
Revision: 00000000 Serial number: 00000000000000
Coding: 0000008
Shop #: WSC 06403 785 00200
VCID: 7CFCF6AE00B171FC
1 Fault Found
18265 - Load Signal: Error Message from ECU
P1857 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 9
Reset counter: 190
Mileage: 85709 km
Time Indication: 0
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00012
Shop #: WSC 06402
VCID: 3C7C36AE4031B1FC
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 AD
Component: 03 AIRBAG VW5 0010
Coding: 12339
Shop #: WSC 06401
VCID: 79F2EFBA0F8344D4
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 801 A
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 00134
Shop #: WSC 64764
VCID: 2756F9C2A9B70224
1 Fault Found
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0068 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
VCID: F0E4529EDCF9859C
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10151
Shop #: WSC 06402
VCID: 6FE6D1E241C71A64
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 0J Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
VCID: 3D7A3BAA5B2BB8F4
Part No: 6Q2959802A
Component: 0J Tõrsteuer.FS KLO 0202
Part No: 6Q2959801A
Component: 0J Tõrsteuer.BF KLO 0202
1 Fault Found
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
End ---------------------------------------------------------------------
Um é relacionado com problemas de alternador, outro da egr, outro é o sensor da temperatura exterior que deve estar pifado, aquele da centralina não sei o que seja, qualquer coisa com a centralina.
Já apagas-te os erros e voltas-te a verificar a ver se são permanentes?
sim...apagei e sao permanentes :S
